Cisco SCCP book
raziel78kain
Level 2
Level 2
is there a "Cisco SCCP only" book out there?
Best regards.
phooghen
I don't think you will find any book on the SCCP protocol since it's a Cisco proprietary protocol.
But if you google, you will find quite a lot of information (wikipedia)
thanks for the answer.
Can you suggest me a good "Cisco VOIP troubleshooting" book (i.e. not necessarily related only to the SCCP protocol), then?
Thanks and regards.
While a little bit outdated, the following book is still a good reference:
Troubleshooting Cisco IP Telephony
ISBN:  978-1-58705-344-3
ISBN-10: 1-58705-344-6
Pierre.
