Cisco SDM - Security Device Manager
deepfree1
Hello gents,
Please need your advice. I think i am facing with problem launching SDM to remote Router.
And the problem is with java security i think it doesnt give me rights to connect. Everytime i am trying its just showing me loading information thats all. I know that i can adjust Java security at the setting but its all about URL. Where can a set to the SDM launcher ?
How can i fix it ?
Thanks in advance
Jaime Valencia
You're posting in the IP Telephony forum, I suggest you move this to a relevant area.
java
if this helps, please rate
