No MOH - Restart cisco ip voice media streaming app fixes the problem
mathew.lear
Hello All,
I have a call manager 10.5.2.12901-1 cluster and cisco ip voice media streaming app running on the two TFPT nodes.
Since the install in January we have had two tickets come through where calls are receiving silent MOH.
On both occasions, this has been fixed by restarting the service "cisco ip voice media streaming app"
I do see this in the traces :
19:33:15.838 HDR|03/23/2018 VoiceStrm,StandAloneCluster,192.168.1.20,Error,10.5.2.12901-1
19:33:15.838 |   PITrace: *ERROR* [CRITIAL INFO]: platform install api isDeployedStandalone()= true
19:33:15.838 |   PITrace: *ERROR* [CRITIAL INFO]: platform install api prods[0]=CallManager
19:33:15.838 |   PITrace: *ERROR* [CRITIAL INFO]: Platform Box Configuration :0 (CCM:0,UNITY:1,CoRes:2,Unknown:3)
19:33:15.838 |   PITrace: *ERROR* Important info only, Category[DBMon]: productid_enable_flag=1, system_enable_flag=1
19:33:15.838 |   PITrace: *ERROR* Important info only, Category[Cisco Tomcat]: productid_enable_flag=1, system_enable_flag=1
19:33:15.838 |   PITrace: *ERROR* Important info only, Category[Cisco LDAP Directory]: productid_enable_flag=1, system_enable_flag=1
19:33:15.838 |   PITrace: *ERROR* Important info only, Category[SAML SSO]: productid_enable_flag=1, system_enable_flag=1
19:33:15.838 |   PITrace: *ERROR* Important info only, Category[CallManager]: productid_enable_flag=1, system_enable_flag=1
19:33:15.838 |   PITrace: *ERROR* Important info only, Category[LBM]: productid_enable_flag=1, system_enable_flag=1
19:33:15.838 |   PITrace: *ERROR* Important info only, Category[CmiManager]: productid_enable_flag=1, system_enable_flag=1
19:33:15.838 |   PITrace: *ERROR* Important info only, Category[CtiManager]: productid_enable_flag=1, system_enable_flag=1
19:33:15.838 |   PITrace: *ERROR* Important info only, Category[Cisco Media Streaming App]: productid_enable_flag=1, system_enable_flag=1
19:33:15.838 |   PITrace: *ERROR* Important info only, Category[CiscoEM]: productid_enable_flag=1, system_enable_flag=1
19:33:15.838 |   PITrace: *ERROR* Important info only, Category[CiscoWebdialer]: productid_enable_flag=1, system_enable_flag=1
19:33:15.838 |   PITrace: *ERROR* Important info only, Category[CiscoIPMA]: productid_enable_flag=1, system_enable_flag=1
19:33:15.838 |   PITrace: *ERROR* Important info only, Category[CAR]: productid_enable_flag=1, system_enable_flag=1
19:33:15.838 |   PITrace: *ERROR* Important info only, Category[Cisco TFTP]: productid_enable_flag=1, system_enable_flag=1
19:33:15.838 |   PITrace: *ERROR* Important info only, Category[CiscoAXLWebService]: productid_enable_flag=1, system_enable_flag=1
19:33:15.838 |   PITrace: *ERROR* Important info only, Category[RISSystemAccess]: productid_enable_flag=1, system_enable_flag=1
19:33:15.838 |   PITrace: *ERROR* [IMPORTANT INFO]  AppCrashCheckBase::AppCrashCheckBase() the RW_Process_Mutex is :/dev/shm/Category_CiscoMediaStreamingApp_Mutex_crash_checker
19:33:15.839 |   PITrace: *ERROR* [IMPORTANT INFO] AppCrashCheckBase::AppCrashCheckBase() acquire lock successed. : errno = 0; strerr = Success
19:33:15.839 |   PITrace: *ERROR* [IMPORTANT INFO]WriterSideCheck() open existing flag_check_mmf left from last run. : errno = 17; strerr = File exists
19:33:15.839 |   PITrace: *ERROR* [IMPORTANT INFO]ExAppCrashCheck::WriterSideCheck() create/open flag_check_mmf successed!!! : errno = 17; strerr = File exists
19:33:15.839 |   PITrace: *ERROR* {Debug infomation}: look from writer side, writer crashed last time : true
19:33:15.839 |   PITrace: *ERROR* CPICategory::loadXmlFile() Category: [Cisco Media Streaming App] xmlfile: [/usr/local/cm/conf/MediaAppPerfmon.xml]
19:33:15.840 |   PITrace: *ERROR* CPIClass::createMMF() MMF file : [/Category_CiscoMediaStreamingApp_PIClass_MEDIAAPP_GLOBAL_OBJECT_MDB] is started.(no error)
19:33:15.840 |   PITrace: *ERROR* ExObjectUpdateTracker::ExObjectUpdateTracker::_synchronizeMAP() m_nIndex  :0 m_nRoundCount : 0  m_nTick: 0
19:33:15.840 |   PITrace: *ERROR* [SIGNIFICANT INFO]Category Name: Cisco Media Streaming App file: /usr/local/cm/conf/MediaAppPerfmon.xml enbled_flag: 1
19:33:15.840 |   PITrace: *ERROR* [SIGNIFICANT INFO]Add ITraceObj for Category Name: Cisco Media Streaming App, tid:32702l
19:33:15.840 |   PITrace: *ERROR* [SIGNIFICANT]::statsInit() enable_flag=1
Any ideas ?
When it stops working do you see errors in RTMT?
Have you checked during hold if media stream is allocated by the registered
CUCM from CLI?
show perf query class "Cisco MOH Device"
Hello Mohammed,
I will create an action plan with the above steps in case it happens again.
Thanks for the feedback,
Mathew
Not aware of a bug on this version which can cause this, Also along with the info already asked for please pull detailed Callmanager and IPVMSA logs along with the details of the call (calling number, called number, timestamp) when this issue happens.To further isolate this issue you would also want to confirm if the issue is seen only seen when an external number is involved or if it's seen for internal calls as well.
Please rate if you find this helpful.
Aeby
Aeby
