Cisco SIP Phone 9971 won't register on CME 8.6 or 8.5 Please HELP
gossa1973
Please help me , I have problem with registering Cisco SIP phone 9971 with CME 8.6 on ISR 2901.
I configured CME for SIP clients, then I add configuration for 9971 phone and create profiles.  Phone downloaded SEP...xml file from CME,after that phone look for g4-tones.xml and gd-sip.jar files, I added them to CME after that phone downloaded them and reboot. Now phone is stuck in some kind of loop and does not register on CME.
On phone log I can see repeting next few messeges.
12:01:58a No DNS Server IP
12:01:59a Updating Trust list
12:01:59a No Trust List instaled
12:01:59a SEP04C5AB03B0D.cnf.xml (TFTP)  // at this time phone download SEP...xml file from CME
12:02:00a VPN Error: VPN is not Configured
on CME if issue DEBUG TFTP EVENTS i receive next few lines
*Aug 18 18:20:19.891: TFTP: Looking for CTLSEP04C5A4B03B0D.tlv
*Aug 18 18:20:19.987: TFTP: Looking for ITLSEP04C5A4B03B0D.tlv
*Aug 18 18:20:20.083: TFTP: Looking for ITLFile.tlv
*Aug 18 18:20:20.347: TFTP: Looking for SEP04C5A4B03B0D.cnf.xml
*Aug 18 18:20:20.351: TFTP: Opened flash:/SEP04C5A4B03B0D.cnf.xml, fd 14, size 4585 for process 141
*Aug 18 18:20:20.363: TFTP: Finished flash:/SEP04C5A4B03B0D.cnf.xml, time 00:00:00 for process 141
here you can see verison info of CME
Cisco IOS Software, C2900 Software (C2900-UNIVERSALK9-M), Version 15.1(4)M, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2011 by Cisco Systems, Inc.
Compiled Thu 24-Mar-11 15:31 by prod_rel_team
ROM: System Bootstrap, Version 15.0(1r)M9, RELEASE SOFTWARE (fc1)
ELTOSAN_ROUTER uptime is 1 hour, 50 minutes
System returned to ROM by reload at 16:29:20 UTC Thu Aug 18 2011
System image file is "flash:/c2900-universalk9-mz.SPA.151-4.M.bin"
Last reload type: Normal Reload
Last reload reason: Reload Command
Cisco CISCO2901/K9 (revision 1.0) with 471040K/53248K bytes of memory.
Processor board ID FGL1508252Y
3 Gigabit Ethernet interfaces
2 terminal lines
1 Virtual Private Network (VPN) Module
4 Voice FXO interfaces
4 Voice FXS interfaces
1 Internal Services Module (ISM) with Services Ready Engine (SRE)
   Survivable Remote Site Voicemail (SRSV) on Cisco Unity Express (CUE) 8.5.1 in slot/sub-slot 0/0
DRAM configuration is 64 bits wide with parity enabled.
255K bytes of non-volatile configuration memory.
254464K bytes of ATA System CompactFlash 0 (Read/Write)
License Info:
License UDI:
Device#   PID                   SN
*0        CISCO2901/K9          xxxxxxxxxxxxx
Technology Package License Information for Module:'c2900'
Technology    Technology-package          Technology-package
              Current       Type          Next reboot
ipbase        ipbasek9      Permanent     ipbasek9
security      securityk9    Permanent     securityk9
uc            uck9          Permanent     uck9
data          None          None          None
this is RUNNING CONFIGURATION
! Last configuration change at 16:10:12 UTC Thu Aug 18 2011
version 15.1
hostname ELTOSAN_ROUTER
boot-start-marker
boot system flash:/c2900-universalk9-mz.SPA.151-4.M.bin
boot-end-marker
no aaa new-model
no ipv6 cef
ip source-route
no ip routing
no ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 192.168.5.1 192.168.5.10
ip dhcp excluded-address 192.168.5.200 192.168.5.255
ip dhcp pool phone
   network 192.168.5.0 255.255.255.0
   default-router 192.168.5.251
   option 150 ip 192.168.5.251
ip dhcp pool data
   relay source 192.168.2.0 255.255.255.0
   relay destination 192.168.2.201
voice-card 0
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
supplementary-service h450.12
fax protocol pass-through g711alaw
sip
  registrar server expires max 3600 min 120
voice register global
mode cme
source-address 192.168.5.251 port 5060
max-dn 6
max-pool 6
load 9971 sip9971.9-1-1SR1.loads
authenticate register
tftp-path flash:
create profile sync 0005135312289902
voice register dn  1
number 207
allow watch
name GossaVM
label 207
voice register dn  3
number 101
name Dejan
label 101
mwi
voice register pool  1
id mac 000C.29C5.0011
number 1 dn 1
dtmf-relay sip-notify
username testvm password testera
codec g711alaw
voice register pool  3
id mac 04C5.A4B0.3B0D
type 9971
number 3 dn 3
presence call-list
dtmf-relay rtp-nte
username dejan password 1234
codec g711alaw
no vad
license udi pid CISCO2901/K9 sn xxxxxxxxxxxx
hw-module ism 0
hw-module pvdm 0/0
redundancy
interface GigabitEthernet0/0
description INTERFACE INTERNAL
no ip address
no ip route-cache
duplex auto
speed auto
no mop enabled
interface GigabitEthernet0/0.2
description LAN DATA
encapsulation dot1Q 2
ip address 192.168.2.251 255.255.255.0
no ip route-cache
interface GigabitEthernet0/0.5
description LAN VOICE
encapsulation dot1Q 5
ip address 192.168.5.251 255.255.255.0
no ip route-cache
interface ISM0/0
no ip address
no ip route-cache
shutdown
!Application: SRSV-CUE Running on ISM
interface GigabitEthernet0/1
no ip address
no ip route-cache
shutdown
duplex auto
speed auto
interface ISM0/1
description Internal switch interface connected to Internal Service Module
shutdown
interface Vlan1
no ip address
no ip route-cache
shutdown
ip forward-protocol nd
no ip http server
no ip http secure-server
snmp-server community public RO
tftp-server flash:dkern9971.100609R2-9-1-1SR1.sebn alias dkern9971.100609R2-9-1-1SR1.sebn
tftp-server flash:kern9971.9-1-1SR1.sebn alias kern9971.9-1-1SR1.sebn
tftp-server flash:rootfs9971.9-1-1SR1.sebn alias rootfs9971.9-1-1SR1.sebn
tftp-server flash:sboot9971.031610R1-9-1-1SR1.sebn alias sboot9971.031610R1-9-1-1SR1.sebn
tftp-server flash:skern9971.022809R2-9-1-1SR1.sebn alias skern9971.022809R2-9-1-1SR1.sebn
tftp-server flash:sip9971.9-1-1SR1.loads alias sip9971.9-1-1SR1.loads
tftp-server flash:United_States/g4-tones.xml
tftp-server flash:English_United_States/gd-sip.jar
control-plane
voice-port 0/0/0
voice-port 0/0/1
voice-port 0/0/2
voice-port 0/0/3
voice-port 0/1/0
voice-port 0/1/1
voice-port 0/1/2
voice-port 0/1/3
mgcp profile default
gatekeeper
shutdown
line con 0
line aux 0
line 67
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
password jebiga
login
transport input all
end
I did not have any kind of problem with X-LITE to register to CME. also try with few SCCP phones 7940  and I did not any kind of problem .
this is content of SEP....xml file for 9971
<device>
<deviceProtocol>SIP</deviceProtocol>
<devicePool>
<dateTimeSetting>
<dateTemplate>M/D/YA</dateTemplate>
<timeZone>Pacific Standard/Daylight Time</timeZone>
<ntps>
<ntp priority="0">
<name>0.0.0.0</name>
<ntpMode>unicast</ntpMode>
</ntp>
</ntps>
</dateTimeSetting>
<callManagerGroup>
<members>
<member priority="0">
<callManager>
<ports>
<sipPort>5060</sipPort>
</ports>
<processNodeName>192.168.5.251</processNodeName>
</callManager>
</member>
</members>
</callManagerGroup>
</devicePool>
<sipProfile>
<sipProxies>
<registerWithProxy>true</registerWithProxy>
</sipProxies>
<sipCallFeatures>
<cnfJoinEnabled>true</cnfJoinEnabled>
<localCfwdEnable>true</localCfwdEnable>
<callForwardURI>service-uri-cfwdall</callForwardURI>
<callPickupURI>service-uri-pickup</callPickupURI>
<callPickupGroupURI>service-uri-gpickup</callPickupGroupURI>
<callHoldRingback>2</callHoldRingback>
<semiAttendedTransfer>true</semiAttendedTransfer>
<anonymousCallBlock>2</anonymousCallBlock>
<callerIdBlocking>2</callerIdBlocking>
<dndControl>2</dndControl>
<remoteCcEnable>true</remoteCcEnable>
</sipCallFeatures>
<sipStack>
<remotePartyID>true</remotePartyID>
</sipStack>
<sipLines>
<line button="1" lineIndex="1">
<featureID>9</featureID>
<featureLabel></featureLabel>
<proxy>USECALLMANAGER</proxy>
<port>5060</port>
<name></name>
<displayName></displayName>
<autoAnswer>
<autoAnswerEnabled>2</autoAnswerEnabled>
</autoAnswer>
<callWaiting>1</callWaiting>
<authName>dejan</authName>
<authPassword>1234</authPassword>
<sharedLine>false</sharedLine>
<messagesNumber></messagesNumber>
<ringSettingActive>5</ringSettingActive>
<forwardCallInfoDisplay>
<callerName>true</callerName>
<callerNumber>true</callerNumber>
<redirectedNumber>true</redirectedNumber>
<dialedNumber>true</dialedNumber>
</forwardCallInfoDisplay>
</line>
<line button="2" lineIndex="2">
<featureLabel>101</featureLabel>
<port>5060</port>
<name>101</name>
<displayName>Dejan Rakic</displayName>
<autoAnswer>
</autoAnswer>
</line>
</sipLines>
<enableVad>true</enableVad>
<preferredCodec>g711alaw</preferredCodec>
<dialTemplate></dialTemplate>
<kpml>1</kpml>
<phoneLabel></phoneLabel>
<stutterMsgWaiting>2</stutterMsgWaiting>
<disableLocalSpeedDialConfig>true</disableLocalSpeedDialConfig>
<dscpForAudio>184</dscpForAudio>
<dscpVideo>136</dscpVideo>
</sipProfile>
<commonProfile>
<phonePassword>1234</phonePassword>
<callLogBlfEnabled>2</callLogBlfEnabled>
</commonProfile>
<featurePolicyFile>featurePolicyDefault.xml</featurePolicyFile>
<loadInformation>sip9971.9-1-1SR1.loads</loadInformation>
<vendorConfig>
</vendorConfig>
<commonConfig>
<videoCapability>0</videoCapability>
<ciscoCamera>0</ciscoCamera>
</commonConfig>
<sshUserId>dejan</sshUserId>
<sshPassword>1234</sshPassword>
<userId></userId>
<phoneServices>
<provisioning>2</provisioning>
<phoneService  type="1" category="0">
<name>Missed Calls</name>
<url>Application:Cisco/MissedCalls</url>
<vendor></vendor>
<version></version>
</phoneService>
<name>Received Calls</name>
<url>Application:Cisco/ReceivedCalls</url>
<vendor></vendor>
<version></version>
</phoneService>
<name>Placed Calls</name>
<url>Application:Cisco/PlacedCalls</url>
<vendor></vendor>
<version></version>
</phoneService>
<phoneService  type="2" category="0">
<name>Voicemail</name>
<url>Application:Cisco/Voicemail</url>
<vendor></vendor>
<version></version>
</phoneService>
</phoneServices>
<versionStamp>0131511014412102</versionStamp>
<userLocale>
<name>English_United_States</name>
<langCode>en</langCode>
</userLocale>
<networkLocale>United_States</networkLocale>
<networkLocaleInfo>
<name>United_States</name>
</networkLocaleInfo>
<authenticationURL></authenticationURL>
<directoryURL></directoryURL>
<servicesURL>http://192.168.5.251:80/CMEserverForPhone/serviceurl</servicesURL>
<dscpForSCCPPhoneServices>0</dscpForSCCPPhoneServices>
<dscpForCm2Dvce>96</dscpForCm2Dvce>
<transportLayerProtocol>2</transportLayerProtocol>
</device>
19 Replies 19
I'm facing exactly the same problem, that is:
a Cisco SIP Phone 9971 won't register on CME 8.6 running on a 2811
I have read all the postings to this Forum, but I have not been able to solve it.
In my case the commands voice register dn  and  voice register pool are OK.
So frankly, I have no idea what I could be missing.
I'm pasting the Router's config.
I hope somebody is able to point me in the right direction.
Here is the config.  Thank you!
C2811#sh run
Building configuration...
version 15.1
hostname C2811
no aaa new-model
dot11 syslog
ip source-route
ip cef
ip dhcp excluded-address 172.25.140.1 172.25.140.10
ip dhcp excluded-address 172.35.140.1 172.35.140.10
ip dhcp pool Data
network 172.25.140.0 255.255.255.0
default-router 172.25.140.1
option 150 ip 172.25.140.1
dns-server 172.25.140.1
ip dhcp pool Voice
network 172.35.140.0 255.255.255.0
default-router 172.35.140.1
option 150 ip 172.35.140.1
dns-server 172.35.140.1
no ip domain lookup
no ipv6 cef
voice service voip
sip
mode cme
source-address 172.25.140.1 port 5060
max-dn 40
max-pool 42
load 9971 sip9971.9-4-1-9.loads
authenticate realm cisco
tftp-path flash:
create profile sync 0004820400584603
voice register dn  1
number 1010
allow watch
name Phone10
label Phone10
mwi
id mac 189C.5DB6.BD09
type 9971
number 1 dn 1
presence call-list
dtmf-relay rtp-nte
username adm password adm
call-forward b2bua busy 68600
codec g711ulaw
no vad
camera
video
voice-card 0
crypto pki trustpoint TP-self-signed-1879153754
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-1879153754
revocation-check none
rsakeypair TP-self-signed-1879153754
crypto pki certificate chain TP-self-signed-1879153754
certificate self-signed 01
(details ommited)
license udi pid CISCO2811 sn FTX1146A44H
username admin privilege 15 password 0 admin
redundancy
interface FastEthernet0/0
no ip address
duplex auto
speed auto
interface FastEthernet0/0.25
description Data VLAN
encapsulation dot1Q 25
ip address 172.25.140.1 255.255.255.0
interface FastEthernet0/0.35
description Voice VLAN
encapsulation dot1Q 35
ip address 172.35.140.1 255.255.255.0
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
ip http server
ip http authentication local
ip http timeout-policy idle 600 life 86400 requests 10000
tftp-server flash:P00308010200.bin
tftp-server flash:P00308010200.sbn
tftp-server flash:P00308010200.sb2
tftp-server flash:P00308010200.loads
tftp-server flash:SCCP42.9-3-1SR3-1S.loads
tftp-server flash:apps42.9-3-1ES19.sbn
tftp-server flash:cnu42.9-3-1ES19.sbn
tftp-server flash:cvm42sccp.9-3-1ES19.sbn
tftp-server flash:dsp42.9-3-1ES19.sbn
tftp-server flash:jar42sccp.9-3-1ES19.sbn
tftp-server flash:term42.default.loads
tftp-server flash:term62.default.loads
tftp-server flash:SCCP45.9-3-1SR3-1S.loads
tftp-server flash:apps45.9-3-1ES19.sbn
tftp-server flash:cnu45.9-3-1ES19.sbn
tftp-server flash:cvm45sccp.9-3-1ES19.sbn
tftp-server flash:dsp45.9-3-1ES19.sbn
tftp-server flash:jar45sccp.9-3-1ES19.sbn
tftp-server flash:term45.default.loads
tftp-server flash:term65.default.loads
tftp-server flash:/Ringtones/Ringlist.xml alias Ringlist.xml
tftp-server flash:/Ringtones/DistinctiveRingList.xml alias DistinctiveRingList.x
ml
tftp-server flash:sip9971.9-4-1-9.loads
tftp-server flash:kern9971.9-4-1-9.sebn
tftp-server flash:rootfs9971.9-4-1-9.sebn
tftp-server flash:dkern9971.100609R2-9-4-1-9.sebn
tftp-server flash:sboot9971.031610R1-9-4-1-9.sebn
tftp-server flash:skern9971.022809R2-9-4-1-9.sebn
tftp-server flash:/g4-tones.xml alias United_States/g4-tones.xml
tftp-server flash:/gd-sip.jar alias English_United_States/gd-sip.jar
control-plane
telephony-service
max-ephones 24
max-dn 48
ip source-address 172.25.140.1 port 2000
cnf-file location flash:
load 7960-7940 P00308010200
load 7942 SCCP42.9-3-1SR3-1S.loads
load 7945 SCCP45.9-3-1SR3-1S.loads
load 7962 SCCP42.9-3-1SR3-1S.loads
load 7965 SCCP45.9-3-1SR3-1S.loads
max-conferences 8 gain -6
dn-webedit
transfer-system full-consult
create cnf-files version-stamp 7960 Feb 11 2014 07:18:32
ephone-dn  1
number 1001
description Phone 1
name Phone 1
hold-alert 30 originator
ephone-dn  2
number 1002
description Phone 2
name Phone 2
ephone-dn  3
number 1003
description Phone 3
name Phone 3
ephone  1
device-security-mode none
mac-address 001C.58FB.6E0F
button  1:1
ephone  2
mac-address 0014.A981.7F8A
button  1:2
ephone  3
mac-address 0006.5356.A4B8
button  1:3
alias exec con conf t
alias exec sib show ip int brief
alias exec srb show run | b
alias exec sri show run int
line con 0
exec-timeout 0 0
logging synchronous
line aux 0
line vty 0 4
privilege level 15
login local
transport input telnet ssh
transport output telnet ssh
line vty 5 15
privilege level 15
login local
scheduler allocate 20000 1000
ntp master 1
end
C2811#
Hi All,
Does any one was able to figure out the issue
Many Thanks
Ilya Geraskin
Hello all
I've faced with the same but a little bit different trouble.
The phone in understanding of CME is Registered.
1    2037.0617.D891  172.4.4.3       1  1   103                  REGISTERED   1  1   103                  REGISTER
But phone is stiull display "phone is not registered"
In status messages there is dome messages about no tls file founded  and no vpn configured.
Everything seems configured properly but it still doesn't work.
ccsip messages show something strange:
Many messages like:
Received:
REGISTER sip:172.4.4.1 SIP/2.0
Sent:
SIP/2.0 200 OK
and after 3-5 times of OK it starts to send
Received:
Sent:
SIP/2.0 100 Trying
Sent:
SIP/2.0 500 Internal Server Error
IOS ver is15.2(1)GC
FIrmware is 9-2-3-27
What could it be?
Hello Ilya! Did u solved registration problem?
Good luck
CCIE, Irkutsk, Russia
Sincerely from Nik
It seems that problem occurs when you are using sip-ua for sip-lines. I've tried to delete sip-ua configuration and everything goes well after that. We just stopped to use sip-proxy and have connected to the true SIP-trunk with IP auth.
But may be it was fixed in latest release that appeared in the end of march.
