Cisco Sip phone RTP statistics
kwillocx
I have a C7940G in SIP firmware POS3-08-6-00.
I need to regularly check the RTP counters by telnetting to it and do "sh rtp".
But I need a way to reset these counters.
Clear RTP doen't exist so the only way I found was to reset the phone ; which is obviously a bit too drastic.
Does anyone know another way to clear these counters ?
kris.willocx@belgacom.be
t.silva
Hi Kris,
Try 'show rtp clear' command.
Please rate this post, if it helps you.
t.silva
Hi Kris,
Indeed , it works.
Thanks a lot.
