Cisco SPA504G on Callmanager 8.5.1
tim.stapleford
The question is, is it possible to register a SPA504G on callmanager 8.5.1 and if so how do you do it please.
I believe the hands free audio is clearer than other phones such as 7962G, we have loads of 7937G's for larger conf rooms, these are for smaller break out rooms.
If not can anyone recommend a decent smaller hands free phone for callmanager.
Tim
Jaime Valencia
It can be registered as a SIP 3rd party endpoint, the admin guide for CUCM contains an appendix on configuring this kind of devices.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Cheers, I'll give it a go.
