Configure Speed dial on Analog phone
Saima Harris
How can I configure speed dial on an Analog phone when you are using VG224 and Call Manager 8.6.
Here is configuration I tried but I'm stuck after that, Is there anything else that needs to be configured on VG224 and also what would be the CM config :
VG224-1(config)#stcapp call-control mode feature
VG224-1(config)#stcapp feature speed-dial
VG224-1(config-stcapp-fsd)#digit 1
VG224-1(config-stcapp-fsd)#prefix *
VG224-1(config-stcapp-fsd)#exit
Saima
Hi Saima,
It doesn't matters what kind of anaolg phone you have, unless it is connected via the VG224, follow the below steps to configure it.
  • Assuming that you have already added VG224 in CUCM, and have assigned the DN to the analog ports.
  • Go to your CUCM administration Page and navigate to User Management --> End user --> Search the user --> In controlled Devices, search the DN and select the DN/analog device that you want to associate with this user.
    • In Permission information, assign the "Standard CCM End users" to the groups.
    • Now access the URL https://:8443/ccmuser, login with the users credentials.
    • Go to User Options --> Device --> Click on Speed Dials and now start configuring it.
    If this helps, please rate the post.
    Gifton Abel.
    giftonabel
    You missing the below highlighted command ,
    Router#stcapp feature speed-dial
    digit 1
    prefix *
    speed dial from 1 to 9
    Router# show stcapp feature codes
        prefix *
        speeddial1 *1
        speeddial2 *2
        speeddial3 *3
        speeddial4 *4
        speeddial5 *5
        speeddial6 *6
        speeddial7 *7
        speeddial8 *8
        speeddial9 *9
    Now configure the Speed dial numbers in the ccmuser page.
    Note: to support upto 99 speed dials, need to configure
    digit 2
    HTH,
    Gifton Abel.
    Thanks for the information Gifton.
    Ho do I configure speed dial numbers in CM (ccmuser page),   providing its an Analog Astra phone.
    Hi Saima,
      Gifton Abel.
      Thanks for your help .
      Worked like a charm
      Saima
