Cisco Spark SIP Logs
parzee_forums
How can I retrieve SIP logs from Spark client?
I know Spark uses TLS hence a packet capture is not an option.
Manish Gogna
Please check the following
https://help.webex.com/docs/DOC-4092#jive_content_id_Cisco_Spark
Additionally, on Windows PC you can also check the client logs under the following folder
Users\UserName\AppData\Local\CiscoSpark
Manish
Manish Gogna
Manish
Once you send feedback , we can fetch the logs for you from CCM portal
Lokesh K. Lal
Engineering Product Manager
Cisco Systems Inc.
Please don't forget to rate useful posts
