Turning on Cisco 7940CP
celmassry
how do i turn this phone on?
I connected it to my internet and its not turning on??
Christian
6 Replies 6
Adarsh Chauhan
Level 3
Level 3
What do you mean by its not turning on?
Did you plug in rj45 to its back with other end that supports Power over Ethernet?
Please rate and mark if helpful
Adarsh Chauhan
Please rate and mark correct if helpful
Adarsh Chauhan
from my router, i plug in the cat 5 connection. .. nothing...
You need to connect it to a switchport that can supply 6.3 Watt of power, there are certain PoE requirements that need to be met as per the following
http://www.cisco.com/c/en/us/support/docs/voice-unified-communications/unified-ip-phone-7900-series/97869-poe-requirement-faq.html
https://supportforums.cisco.com/discussion/11693621/powering-poe-7940g-ip-phones
Manish
can you please give me an example of where i can get this switch port?
Switchports are available on switches, if you don't have a Cisco switch then buying a new one for just one phone will not make sense. What is your existing infrastructure, for getting better support on the forums you need to provide details of the device models, firmware/ios details otherwise the posts will go unanswered or stretch for days.
Manish
Jaime Valencia
If you do not have a PoE switch or module on your ISR, you can always just buy a power cube
http://www.cisco.com/c/en/us/products/collateral/collaboration-endpoints/unified-ip-phone-7940g/product_data_sheet09186a008008884a.html
java
if this helps, please rate
