Cisco Switch > Phone > PC Daisy Chain
bwong
We have a 3500XL with IOS 12.0(5)WC17 that will not configure a daisy chain for a switch > cisco phone > PC connection.
I'm having trouble configuring our switch to run both voice VLAN traffic and our data vlan traffic through a Fast Ethernet port.
On my other switches, I use these commands:
interface FastEthernet0/18
      switchport
      switchport access vlan 4
      switchport mode access
      switchport voice vlan 101
      no ip address
      spanning-tree portfast
Vlan 4 is our data network and Vlan 101 is voice.
When I try running those commands and then do a show running-config on the 3500XL this is what I get:
The commands "no ip address" and "switchport mode access" don't seem to work.
Anybody have any ideas on how to get this to work?
Thank you for your time!
Brandon,
Can you try this config for your PHONE/PC ports
desc *** PHONE & PC PORT ***
switchport trunk native vlan 4
switchport mode trunk
switchport priority extend cos 0
no shut
Can you also verify that the vlans have been created or propogated to your switch via VTP
show vlan
Alex.
Please rate useful posts.
Regards, Alex. Please rate useful posts.
Leo Laohoo
The commands are not "valid".
The 3500XL is a Layer 2-only switch so you can't configure IP address on an interface.  This means the command "no ip address" is not valid.
Interface FastEthernet 0/18 is already in "switchport mode access" (default) because you have one data and one voice VLAN.  The line "switchport trunk encapsulation dot1q" is not being used because the interface is an access port.
Thanks for the response Leolaohoo!
The current config allows for the PC to acquire a 4 address but the phone gets stuck in "Configuring IP" and never boots up properly.
Brandon,
no shut
show vlan
Alex.
Thank you for your help Alex, this worked perfectly!
