Hello Colin,
The best thing I can recommend is for you is to go to the following link:
http://tools.cisco.com/WWChannels/LOCATR/openAdvanceSearch.do
Then under the Authorized Technology Provider section.. choose a Telepresence ATP partner. And set the country for China. You should be able to find a partner by country AND just as importantly.. by region (which is China is almost as important as local language expertise).
John Kim
Worldwide Partner GTM- Telepresence
johnki2@cisco.com
