Branch office CUBE configuration
Matt Smith
I have a voice routing topology question and would like some hints in which documentation I can find what I'm looking for:
Currently:
Running CUCM BE6K at our HQ in North America.
Have a local SIP trunk to our ITSP which is proxy'd by a 2951
Device partition for NA devices
A small branch office in Germany is using a different phone system and needs to be migrated over to CUCM.
Near Future:
2901 CUBE and phones only devices at branch office in Germany.
Have a local SIP trunk to our ITSP which is proxy'd by a 2901
Device partition for German office devices.
I would like to avoid the media stream traversing the ocean back to NA for phone calls originating/terminating in EMEA, and instead have them go out the locally provided trunk.
Any Inter-office call media streams would of course traverse the VPN between offices. I would also like to setup SRST on the 2901 for the German office, whereby the local phones can register if there is an issue with the VPN connection back to CUCM.
What I need:
I'm having some issues finding documentation which outlines how to configure this setup from both the CUCM side and from the CUBE side, and I'm wondering if this setup is supported.
I've found some information that leads me to think a dspfarm on the 2901 is part of the solution to transcode between the trunk and German office phones.
I believe configuring the 2901 as an MTP on CUCM is part of the solution.
Additionally I see some potential problems:
Unity is located in NA and would handle all voicemail for both locations
Uccx is located in NA and would handle IVR (rare occurance)
Any help is appreciated, I currently have the hardware as dicussed and am working through the configurations.
Steve
From the logs I can see that you are doing DO to DO. That implies that you are not offering any SDP to your ITSP for outbound calls...
Configure this and test again on the german cube
conf t
voice service voip
sip
early-offer forced
Please rate all useful posts
"opportunity is a haughty goddess who waste no time with those who are unprepared"
16 Replies 16
dsobrinho
Level 9
Level 9
Hi Steve,
It is a lot of information. Let's party like Jack. Give more information about the config of CUBE.
Best regards,
Daniel
Daniel Sobrinho
What info are you looking for? The branch office 2901 config is pretty minimal. (and as it stands the branch equipment is sitting on my desk).
Steve,
It is pretty straight forward...
1. You will need to configure two sip trunks on CUCM
a. NA SIP trunk pointd to NA CUBE
b. Germany SIP turnk..Points to Gernamy CUBE
2. You will need to create seperate RL, RG and RP..
The NA RP will point to the NA RG
The Germany RP will pointo tthe Germany RG
3. Each phone will have access to their respective RP
4. You then need to configure your CUBE in each location.
You can look at this thread for some recommended best practice on setting up CUBE etc
https://supportforums.cisco.com/message/3884309#3884309
Ok, had some time to look at this again.
Currently I have the German CUBE up and running, but I'm not sure how to stop the media stream from transitioning between German CUBE and NA CUCM.
Right now I believe the media stream is:
Inbound call to German # --> German CUBE --> SIP trunk to CUCM --> SCCP to phone over VPN --> SCCP to CUCM --> SIP trunk to CUBE --> to ITSP
I took a look at the other thread you mentioned, but I'm not sure which part applies. I'd like the CUBE to signal CUCM that a call is destined for one of the phones in the German phones partition, and have the local German phone make the media connection to the local German CUBE.
I think the MTP resources of the German CUBE is what I'm missing.
Here is the current config of the German CUBE:
! Last configuration change at 13:38:48 UTC Wed May 22 2013 by root
version 15.2
hostname 2901-01.miovision.corp
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
no aaa new-model
ip cef
ip dhcp excluded-address 10.10.10.1
ip domain name yourdomain.com
ip name-server 8.8.8.8
ip name-server 8.8.4.4
no ipv6 cef
crypto pki trustpoint TP-self-signed-3973529459
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-3973529459
revocation-check none
rsakeypair TP-self-signed-3973529459
crypto pki certificate chain TP-self-signed-3973529459
certificate self-signed 01
[snip]
            quit
voice-card 0
dspfarm
dsp services dspfarm
voice service voip
ip address trusted list
no ip address trusted authenticate
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
redirect ip2ip
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
sip
  pass-thru content sdp
  registration passthrough
voice class codec 1
codec preference 1 g711alaw
voice class sip-profiles 102
request INVITE sip-header From modify "10.0.249.6" "sip.dcalling.de"
voice class sip-profiles 103
request INVITE sip-header From modify "500@10.0.249.6" "[snip]@sip.dcalling.de"
media service
license udi pid CISCO2901/K9 sn FGL170810CM
hw-module pvdm 0/0
username root privilege 15 secret 4 [snip]
redundancy
ip ssh time-out 60
ip ssh source-interface GigabitEthernet0/0.7
ip ssh version 2
ip ssh pubkey-chain
  username root
csdb tcp synwait-time 30
csdb tcp idle-time 3600
csdb tcp finwait-time 5
csdb tcp reassembly max-memory 1024
csdb tcp reassembly max-queue-length 16
csdb udp idle-time 30
csdb icmp idle-time 10
csdb session max-session 65535
interface Embedded-Service-Engine0/0
no ip address
shutdown
description $ETH-LAN$$ETH-SW-LAUNCH$$INTF-INFO-GE 0/0$
no ip address
duplex auto
speed auto
encapsulation dot1Q 7
ip address 10.0.249.6 255.255.255.0
interface GigabitEthernet0/1
no ip address
shutdown
duplex auto
speed auto
ip forward-protocol nd
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat sip-sbc
ip route 0.0.0.0 0.0.0.0 10.0.249.1
access-list 23 permit 10.0.6.30
access-list 23 permit 10.0.9.39
access-list 23 permit 10.10.10.0 0.0.0.7
access-list 23 permit 10.0.0.0 0.255.255.255
access-list 99 permit 85.88.5.252
access-list 99 permit 85.88.5.240
control-plane
mgcp profile default
sccp local GigabitEthernet0/0.7
sccp ccm 10.0.6.30 identifier 1 version 7.0
dial-peer voice 10 voip
description ** Incoming call from dcalling trunk DID:22145580030 **
destination-pattern 22145580030
session protocol sipv2
session target ipv4:10.0.6.30
session transport udp
incoming called-number 22145580030
voice-class codec 1
dtmf-relay rtp-nte
dtmf-interworking standard
no vad
dial-peer voice 50 voip
dial-peer voice 30 voip
description ** Outgoing call to dcalling trunk **
destination-pattern .T
session target dns:sip.dcalling.de
incoming called-number .T
voice-class codec 1
voice-class sip profiles 103
no vad
dial-peer voice 11 voip
description ** Incoming call, push to cucm for account [snip] **
destination-pattern [snip]
voice-class codec 1
dtmf-relay rtp-nte
no vad
sip-ua
credentials number [snip] username [snip] password 7 [snip] realm sip.dcalling.de
authentication username [snip] password 7 [snip] realm sip.dcalling.de
registrar 1 dns:sip.dcalling.de expires 60
gatekeeper
shutdown
telephony-service
sdspfarm units 1
sdspfarm transcode sessions 20
sdspfarm tag 1 2901-01
max-conferences 8 gain -6
transfer-system full-consult
banner exec
% Password expiration warning.
Cisco Configuration Professional (Cisco CP) is installed on this device
and it provides the default username "cisco" for  one-time use. If you have
already used the username "cisco" to login to the router and your IOS image
supports the "one-time" user option, then this username has already expired.
You will not be able to login to the router with this username after you exit
this session.
It is strongly suggested that you create a new username with a privilege level
of 15 using the following command.
username privilege 15 secret 0
Replace and with the username and password you want to
use.
line con 0
login local
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
session-timeout 60
access-class 23 in
privilege level 15
login local
transport input telnet ssh
line vty 5 15
access-class 23 in
privilege level 15
login local
scheduler allocate 20000 1000
end
Steve,
Media never terminates on CUCM, unless in scenarios where an MTP is used. Media will always terminate on CUBE and the IP Phone. So if a call comes in to your germany CUBE and this call is for a phone in germany then your media will sit  locally between the cube and the ip phone. What you will have going to CUCM in NA is signalling traffic. You are going to have both sccp traffic and sip traffic going to NA..since thats where the CUCM is.
If you are seeing media stream going to CUCM then it is most likely that MTP is been invoked for your calls. This is likely due to DTMF mismatch between the dmtf method negotiated between the endpoints and the sip trunk
Interesting.
I had the "Media Termination Point Required" box checked on the trunk config in CUCM.
After unchecking it, I tried to dial out from the German side and have no inbound audio (including ring tones, absolutely zero speaker audio), but do have outbound audio.
If I dial out from NA to Germany I have audio in both directions.
On the NA CUBE, when calling NA -> Germany #show sip calls:
Total SIP call legs:3, User Agent Client:1, User Agent Server:2
SIP UAC CALL INFO
Call 1
SIP Call ID                : A97BA436-C32B11E2-873C8982-4AB77B30@10.0.250.4
   State of the call       : STATE_ACTIVE (7)
   Substate of the call    : SUBSTATE_NONE (0)
   Calling Number          : anonymous
   Called Number           : 5195132407
   Bit Flags               : 0xC04018 0x10000100 0x80
   CC Call ID              : 85334
   Source IP Address (Sig ): 10.0.250.4
   Destn SIP Req Addr:Port : [10.0.6.30]:5060
   Destn SIP Resp Addr:Port: [10.0.6.30]:5060
   Destination Name        : 10.0.6.30
   Number of Media Streams : 2
   Number of Active Streams: 1
   RTP Fork Object         : 0x0
   Media Mode              : flow-through
   Media Stream 1
     State of the stream      : STREAM_ACTIVE
     Stream Call ID           : 85334
     Stream Type              : voice+dtmf (1)
     Stream Media Addr Type   : 1
     Negotiated Codec         : g711ulaw (160 bytes)
     Codec Payload Type       : 0
     Negotiated Dtmf-relay    : rtp-nte
     Dtmf-relay Payload Type  : 101
     QoS ID                   : -1
     Local QoS Strength       : BestEffort
     Negotiated QoS Strength  : BestEffort
     Negotiated QoS Direction : None
     Local QoS Status         : None
     Media Source IP Addr:Port: [10.0.250.4]:27046
     Media Dest IP Addr:Port  : [10.0.6.30]:30010
   Media Stream 2
     State of the stream      : STREAM_DEAD
     Stream Call ID           : -1
     Stream Type              : video (7)
     Negotiated Codec         : No Codec    (0 bytes)
     Codec Payload Type       : 255 (None)
     Negotiated Dtmf-relay    : inband-voice
     Dtmf-relay Payload Type  : 0
     QoS ID                   : -1
     Media Source IP Addr:Port: [10.0.250.4]:0
     Media Dest IP Addr:Port  : [10.0.6.30]:0
Options-Ping    ENABLED:NO    ACTIVE:NO
   Number of SIP User Agent Client(UAC) calls: 1
SIP UAS CALL INFO
Call 1
SIP Call ID                : 0453a39242d8d1071de6042362e0f79f@173.46.30.12
   Calling Number          : 1264
   Bit Flags               : 0xC0401C 0x10000100 0x4
   CC Call ID              : 85332
   Source IP Address (Sig ): 10.0.1.67
   Destn SIP Req Addr:Port : [173.46.30.202]:5060
   Destn SIP Resp Addr:Port: [173.46.30.202]:5060
   Destination Name        : 173.46.30.202
   Media Stream 1
     Stream Call ID           : 85332
     Stream Type              : voice+dtmf (0)
     QoS ID                   : -1
     Media Source IP Addr:Port: [10.0.1.67]:27132
     Media Dest IP Addr:Port  : [173.46.30.202]:20766
   Media Stream 2
     Stream Call ID           : -1
     Negotiated Codec         : h264 (0 bytes)
     Codec Payload Type       : 99
     QoS ID                   : -1
     Media Source IP Addr:Port: [10.0.1.67]:0
     Media Dest IP Addr:Port  : [173.46.30.202]:0
On the German CUBE, calling NA -> Germany #sip show calls:
Total SIP call legs:2, User Agent Client:1, User Agent Server:1
SIP UAC CALL INFO
Call 1
SIP Call ID                : 66B40749-C32B11E2-AEFBE3B7-54AA1348@10.0.249.6
   Calling Number          : 0015195132407
   Called Number           : 8686170390
   CC Call ID              : 22122
   Source IP Address (Sig ): 10.0.249.6
   Number of Media Streams : 1
   Media Stream 1
     Stream Call ID           : 22122
     Negotiated Codec         : Passthrough (0 bytes)
     QoS ID                   : -1
     Media Source IP Addr:Port: [10.0.249.6]:17140
     Media Dest IP Addr:Port  : [10.0.249.101]:22858
SIP UAS CALL INFO
Call 1
SIP Call ID                : 550e9d824501dfa76c0d2c977aa4dcde@85.88.5.229:5060
   CC Call ID              : 22121
   Destn SIP Req Addr:Port : [85.88.5.252]:5060
   Destn SIP Resp Addr:Port: [85.88.5.252]:5060
   Destination Name        : 85.88.5.252
   Media Stream 1
     Stream Call ID           : 22121
     QoS ID                   : -1
     Media Source IP Addr:Port: [10.0.249.6]:17138
     Media Dest IP Addr:Port  : [85.88.5.240]:21266
Steve,
You need to look at your call routing..Somethings dotn seem to add up...
On the NA CUBE..here is the rtp flow..I assume that this call went from your NA CUBE directly to an IP Phone in germany...Please clarify
I assume that 173.x.x.x. is your ITSP...
ITSP(173.46.30.202)----rtp---CUBE(10.0.1.67)
CUBE(10.0.250.4)--rtp----(10.0.6.30)
From that flow we can see that CUBE in NA is sending its rtp to CUCM, again this suggests that CUBE is sending its media to MTP
For the call to the CUBE in germany...
ITSP(85.88.5.240)----rtp---CUBE(10.0.249.6)
CUBE(10.0.249.6)---rtp---ipphone(10.0.249.101)
Questions...
1. How were these calls placed? The call to gernamy phone..via the germany cube? Did you dial in via the germany DDI..
2. What are these IPs can you clarify. The CUBE in germany only has one interface...10.0.249.6..The ITSP is on 88.88.x.x How are you connecting to the ITSP on this ip address?
3. If you dial from NA the DDI number of the germany phone, these call should go to the NA CUBE. It should go to the germany CUBE, then to CUCM, then to the IP Phone
I need clarifications so I can understand whats going on.
It is also important to know why media for calls in NA are going to the CUCM. I bet it is DTMF related. What model of IP phones are you using..Can you also send the sh run of your NA CUBE.
Finally to get a clearer picture I am going to need the CUCM SDI traces.
We have a dedicated fiber connection to our ITSP in NA (ie: no WAN traffic)
*** Calling from NA to Germany (DID) ***
Media Source IP Addr:Port: [10.0.250.4]:27046  <--- NA CUBE
     Media Dest IP Addr:Port  : [10.0.6.30]:30010 <--- NA CUCM
  Media Source IP Addr:Port: [10.0.1.67]:27132  <--- NA Router to ITSP
     Media Dest IP Addr:Port  : [173.46.30.202]:20766  <--- Upstream ITSP SIP server (not WAN routed)
ITSP(173.46.30.202)----rtp---CUBE(10.0.1.67)   <--- this is ITSP to Router(10.0.1.67)
CUBE(10.0.250.4)--rtp----(10.0.6.30)                  <--- this is CUBE to CUCM (...to my internal phone in NA)
Media Source IP Addr:Port: [10.0.249.6]:17140  <--- German CUBE
     Media Dest IP Addr:Port  : [10.0.249.101]:22858  <--- German phone
     Media Dest IP Addr:Port  : [85.88.5.240]:21266  <--- German ITSP (WAN routed)
Questions...
Correct, DID to DID.
Ext to Ext calls are traversing a VPN connection.
Correct, one interface, NAT'ing.
Yes, I believe this is happening, except there is no audio so the call will connect, but the call can't reach an end point (IVR).
Media to CUCM is likely because Media Termination Point Required is checked - I can play with this this weekend when we're outside of business hours, but could this contribute to one-way audio for the German branch when we're calling DID to DID? I don't have one-way audio with any other calls to NA.
Phones:
Germany 7961
NA 7965 (currently testing with) + 7961
NA CUBE config
! Last configuration change at 17:02:58 UTC Wed May 15 2013 by root
version 15.2
service password-encryption
no service dhcp
hostname 2951-01
boot-start-marker
boot-end-marker
enable secret 4
aaa new-model
aaa local authentication attempts max-fail 3
aaa authentication login root local
aaa session-id common
crypto pki trustpoint TP-self-signed-2512309000
subject-name cn=IOS-Self-Signed-Certificate-2512309000
rsakeypair TP-self-signed-2512309000
crypto pki certificate chain TP-self-signed-2512309000
  quit
ip cef
no ip domain lookup
ip domain name miovision.corp
no ipv6 cef
voice-card 0
voice service voip
  ipv4 173.46.30.218
  ipv4 173.46.30.202
  ipv4 10.0.6.30
  ipv4 10.0.6.31
  ipv4 10.0.6.33
  ipv4 10.0.6.32
  ipv4 10.1.1.4
redirect ip2ip
sip
  no call service stop
voice class codec 1
codec preference 1 g711ulaw
license udi pid CISCO2951/K9 sn FGL170810HD
hw-module pvdm 0/0
username admin privilege 15 secret 4
redundancy
ip ssh time-out 60
ip ssh source-interface GigabitEthernet0/0.42
ip ssh version 2
ip ssh pubkey-chain
  username root
zone security Trusted
no ip address
shutdown
no ip address
no ip route-cache
duplex auto
speed auto
interface GigabitEthernet0/0.41
encapsulation dot1Q 41
ip address 10.0.1.67 255.255.248.0
no ip route-cache
encapsulation dot1Q 42
ip address 10.0.250.4 255.255.255.0
zone-member security Trusted
no ip route-cache
no ip address
shutdown
duplex auto
speed auto
interface GigabitEthernet0/2
no ip address
shutdown
duplex auto
speed auto
ip http server
ip http access-class 99
ip route 0.0.0.0 0.0.0.0 10.0.250.1
ip route 10.0.0.0 255.255.255.0 10.0.250.1
ip route 10.0.6.0 255.255.255.0 10.0.250.1
ip route 10.0.250.0 255.255.255.0 10.0.250.1
ip route 10.1.1.0 255.255.255.0 10.0.250.1
ip route 173.46.30.0 255.255.255.0 10.0.1.65
ip route 173.46.30.202 255.255.255.255 10.0.1.65
ip route 173.46.30.218 255.255.255.255 10.0.1.65
access-list 99 permit 10.0.0.0
access-list 99 permit 10.0.250.0 0.0.0.255
access-list 99 permit any
nls resp-timeout 1
cpd cr-id 1
snmp-server community cis1localkit RO 99
snmp-server enable traps entity-sensor threshold
control-plane
description ** Incoming call from Rogers trunk main line/main line TF **
destination-pattern 5195132407
incoming called-number 5195132407
voice-class codec 1
dtmf-relay rtp-nte
no vad
description ** Incoming call from Rogers trunk to Marketing TF **
destination-pattern 5195149988
incoming called-number 5195149988
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 12 voip
description ** Incoming call from Rogers trunk to Support TF **
destination-pattern 5195149993
incoming called-number 5195149993
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 13 voip
description ** Incoming call from Cologne Trunk **
destination-pattern 2...
incoming called-number 2...
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 21 voip
destination-pattern 4..
session target ipv4:10.1.1.4
incoming called-number 4..
voice-class codec 1
no vad
dial-peer voice 14 voip
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 20 voip
description ** Outbound call to Rogers trunk **
destination-pattern ....T
session target ipv4:173.46.30.202
incoming called-number ....T
voice-class codec 1
no vad
sip-ua
no remote-party-id
retry invite 10
retry register 10
host-registrar
gatekeeper
shutdown
line con 0
login authentication local
line aux 0
line 2
no exec
transport input all
stopbits 1
line vty 0 4
access-class 99 in
exec-timeout 60 0
privilege level 15
transport input ssh
line vty 5 15
access-class 23 in
privilege level 15
end
I'm not sure how to take that trace, looking into it right now.
Okay..So from your responses look like the problem you have is in germany..
The statement above suggest that your problem is with an IVR not a phone...
More questions
1. Did you dial the IVR from a cell phone or you dialled the DID of the german IVR from a cisco phone so the call went from NA CUBE to Germany CUBE?
2. Does this work when you dial an IP phone in germany directly
3. Does this work when you dial from a mobile to an ip phone in germany. or to the IVR
I realized this may have been misleading, what I meant to say was the outbound call from Germany is going out the ITSP's trunk -> PSTN -> and into our HQ phone system without return audio (so I can't hear the IVR or send DTMF to dial an extension once the call is connected). Its the same scenario if I call my NA cell phone from the Germany trunk, I can tap the mic on the German phone and hear it on my cell, but cannot hear anything on the German phone - and when I say no audio I mean zero, no background, hiss, static, nothing at all, almost as if the speaker doesn't work on the handset. Then I reactivate MTP and audio flows in both directions.
So just to be clear, I'm experiencing no issues on the NA side of things, and in fact if I call from NA out our ITSP trunk to the DID of a German phone I have two-way audio. I just wanted to document the call from both CUBE's.
More questions
Successfully dial out from NA to DID of German phone. Audio in both directions.
No issues dialing in either direction internally.
Any calls inbound to the German DID work as expected. Its only outbound calls from Germany to any destination that do not have inbound audio.
Steve can you send me CUCM sdi traces (ensure the trace setting is set to detailed)
Also send me debug ccsip messages from the germany CUBE
Do an outbound test call..include the calling and called number.
Really appreciate your time on this.
I'll preface this info with: the invalid IP address messages are related to our trunk provider in Germany, it has not had an affect on calls before.
2901-01.miovision.corp#debug ccsip messages
SIP Call messages tracing is enabled
2901-01.miovision.corp#terminal monitor
*May 24 17:38:16.365: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
OPTIONS sip:216.16.231.94:26664 SIP/2.0
Via: SIP/2.0/UDP 85.88.5.252:5060;branch=0
To: sip:216.16.231.94:26664
Call-ID: 4326ecd3-c4ed5583-3f4d1@85.88.5.252
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
Sent:
SIP/2.0 400 Bad Request - 'Invalid IP Address'
To: sip:216.16.231.94:26664;tag=51F2AC80-1B6E
Date: Fri, 24 May 2013 17:38:16 GMT
Server: Cisco-SIPGateway/IOS-15.2.4.M2
CSeq: 1 OPTIONS
Content-Length: 0
*May 24 17:38:46.541: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Call-ID: 4326ecd3-1bed5583-115d1@85.88.5.252
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
*May 24 17:38:46.545: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
To: sip:216.16.231.94:26664;tag=51F32260-14D8
Date: Fri, 24 May 2013 17:38:46 GMT
CSeq: 1 OPTIONS
Content-Length: 0
*May 24 17:38:50.445: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
REGISTER sip:sip.dcalling.de:5060 SIP/2.0
Via: SIP/2.0/UDP 10.0.249.6:5060;branch=z9hG4bKB4271D67
From: <>8686170390@sip.dcalling.de>;tag=51F331A0-1181
To: <>8686170390@sip.dcalling.de>
Date: Fri, 24 May 2013 17:38:50 GMT
Call-ID: 8BA784B2-B74E11E2-8002E3B7-54AA1348
User-Agent: Cisco-SIPGateway/IOS-15.2.4.M2
Max-Forwards: 70
Timestamp: 1369417130
CSeq: 45605 REGISTER
Contact: <8686170390>
Expires:  60
Supported: path
Content-Length: 0
*May 24 17:38:50.569: //23306/000000000000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
Via: SIP/2.0/UDP 10.0.249.6:5060;received=216.16.231.94;rport=26664;branch=z9hG4bKB4271D67
Server: DALASON GmbH SIP Proxy
Content-Length: 0
Received:
SIP/2.0 401 Unauthorized
To: <>8686170390@sip.dcalling.de>;tag=c0b858c265d3be265092494badc524c3.3355
WWW-Authenticate: Digest realm="sip.dcalling.de", nonce="519fa6310000912d823357785b1b1c9721abaa732c690ff0"
Content-Length: 0
*May 24 17:38:50.569: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 10.0.249.6:5060;branch=z9hG4bKB428873
Max-Forwards: 70
CSeq: 45606 REGISTER
Expires: 60
Authorization: Digest username="8686170390",realm="sip.dcalling.de",uri="sip:sip.dcalling.de:5060",response="422c59af859900af4ab56d3f3d61f460",nonce="519fa6310000912d823357785b1b1c9721abaa732c690ff0",algorithm=md5
Content-Length: 0
*May 24 17:38:50.693: //23306/000000000000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
Via: SIP/2.0/UDP 10.0.249.6:5060;received=216.16.231.94;rport=26664;branch=z9hG4bKB428873
Content-Length: 0
Received:
SIP/2.0 200 OK
To: <>8686170390@sip.dcalling.de>;tag=c0b858c265d3be265092494badc524c3.172e
Contact: <8686170390>;q=0.5;expires=60;received="sip:216.16.231.94:26664"
Content-Length: 0
*May 24 17:39:16.577: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Call-ID: 4326ecd3-21fd5583-f25d1@85.88.5.252
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
Sent:
To: sip:216.16.231.94:26664;tag=51F397B4-59B
Date: Fri, 24 May 2013 17:39:16 GMT
CSeq: 1 OPTIONS
Content-Length: 0
*May 24 17:39:22.897: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:0015195132407@10.0.249.6:5060 SIP/2.0
Via: SIP/2.0/TCP 10.0.6.30:5060;branch=z9hG4bKad284fdd42cb
From: "TESTING BRANCH" <500>;tag=71642~d732e07f-799a-4d2b-9d6a-ae2aaf54507d-19789738
To: <0015195132407>
Date: Fri, 24 May 2013 17:41:08 GMT
Call-ID: 1c5ed780-19f1a634-3937-1e06000a@10.0.6.30
Supported: timer,resource-priority,replaces
Min-SE:  1800
User-Agent: Cisco-CUCM9.1
Allow: INVITE, OPTIONS, INFO, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY
CSeq: 101 INVITE
Expires: 180
Allow-Events: presence, kpml
Supported: X-cisco-srtp-fallback,X-cisco-original-called
Call-Info: <10.0.6.30:5060>;method="NOTIFY;Event=telephone-event;Duration=500"
Cisco-Guid: 0475977600-0000065536-0000012227-0503709706
Session-Expires:  1800
P-Asserted-Identity: "TESTING BRANCH" <500>
Remote-Party-ID: "TESTING BRANCH" <500>;party=calling;screen=yes;privacy=off
Contact: <500>
Max-Forwards: 70
Content-Length: 0
*May 24 17:39:22.905: //23307/1C5ED7800000/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
To: <0015195132407>
Date: Fri, 24 May 2013 17:39:22 GMT
CSeq: 101 INVITE
Allow-Events: telephone-event
Content-Length: 0
*May 24 17:39:23.017: //23308/1C5ED7800000/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:0015195132407@sip.dcalling.de:5060 SIP/2.0
Via: SIP/2.0/UDP 10.0.249.6:5060;branch=z9hG4bKB42971F
From: "TESTING BRANCH" <>8686170390@sip.dcalling.de>;tag=51F3B0DC-1F3A
To: <>0015195132407@sip.dcalling.de>
Date: Fri, 24 May 2013 17:39:23 GMT
Call-ID: B488E039-C3CF11E2-B856E3B7-54AA1348@10.0.249.6
Supported: timer,resource-priority,replaces,sdp-anat
Min-SE:  1800
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
CSeq: 101 INVITE
Timestamp: 1369417163
Contact: <500>
Expires: 180
Max-Forwards: 69
Content-Length: 0
*May 24 17:39:23.141: //23308/1C5ED7800000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 407 Proxy Authentication Required
Via: SIP/2.0/UDP 10.0.249.6:5060;received=216.16.231.94;rport=26664;branch=z9hG4bKB42971F
To: <>0015195132407@sip.dcalling.de>;tag=c0b858c265d3be265092494badc524c3.7f4c
CSeq: 101 INVITE
Proxy-Authenticate: Digest realm="sip.dcalling.de", nonce="519fa6520000918f1307836b0bc16b901952bd5dcf08b348"
Content-Length: 0
Sent:
ACK sip:0015195132407@sip.dcalling.de:5060 SIP/2.0
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
Sent:
Via: SIP/2.0/UDP 10.0.249.6:5060;branch=z9hG4bKB42A1BE
Min-SE:  1800
CSeq: 102 INVITE
Contact: <500>
Expires: 180
Proxy-Authorization: Digest username="8686170390",realm="sip.dcalling.de",uri="sip:0015195132407@sip.dcalling.de:5060",response="5bc57ea0e5b98e15c7f2c4e1deeab02a",nonce="519fa6520000918f1307836b0bc16b901952bd5dcf08b348",algorithm=md5
Max-Forwards: 69
Content-Length: 0
*May 24 17:39:23.269: //23308/1C5ED7800000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Giving a try
Via: SIP/2.0/UDP 10.0.249.6:5060;received=216.16.231.94;rport=26664;branch=z9hG4bKB42A1BE
CSeq: 102 INVITE
Content-Length: 0
*May 24 17:39:23.601: //23308/1C5ED7800000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
Via: SIP/2.0/UDP 10.0.249.6:5060;rport=26664;received=216.16.231.94;branch=z9hG4bKB42A1BE
Record-Route: <85.88.5.252>
To: <>0015195132407@sip.dcalling.de>;tag=as51c2f9be
CSeq: 102 INVITE
Server: DCALLING PBX
Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REFER, SUBSCRIBE, NOTIFY, INFO
Supported: replaces, timer
Contact: <0015195132407>
Content-Type: application/sdp
Content-Length: 308
v=0
o=root 1794050140 1794050140 IN IP4 85.88.5.233
s=Asterisk PBX 1.6.2.6
c=IN IP4 85.88.5.240
t=0 0
m=audio 21984 RTP/AVP 0 8 3 101
a=rtpmap:0 PCMU/8000
a=rtpmap:8 PCMA/8000
a=rtpmap:3 GSM/8000
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-16
a=silenceSupp:off - - - -
a=ptime:20
a=sendrecv
*May 24 17:39:23.613: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: <0015195132407>;tag=51F3B328-E30
CSeq: 101 INVITE
Remote-Party-ID: <0015195132407>;party=called;screen=no;privacy=off
Supported: replaces
Supported: sdp-anat
Supported: timer
Content-Disposition: session;handling=required
Content-Length: 307
v=0
c=IN IP4 10.0.249.6
t=0 0
m=audio 17172 RTP/AVP 0 8 3 101
a=rtpmap:3 GSM/8000
a=fmtp:101 0-16
a=ptime:20
a=sendrecv
*May 24 17:39:23.669: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:0015195132407@10.0.249.6:5060;transport=tcp SIP/2.0
Via: SIP/2.0/TCP 10.0.6.30:5060;branch=z9hG4bKad2937dc17c7
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 233
v=0
o=CiscoSystemsCCM-SIP 71642 1 IN IP4 10.0.6.30
s=SIP Call
c=IN IP4 10.0.249.101
b=TIAS:64000
b=AS:64
t=0 0
m=audio 17576 RTP/AVP 0 101
a=ptime:20
a=fmtp:101 0-15
*May 24 17:39:23.677: //23308/1C5ED7800000/SIP/Msg/ccsipDisplayMsg:
Sent:
ACK sip:0015195132407@85.88.5.233 SIP/2.0
Via: SIP/2.0/UDP 10.0.249.6:5060;branch=z9hG4bKB42B18F5
Max-Forwards: 70
CSeq: 102 ACK
Content-Length: 231
v=0
s=SIP Call
c=IN IP4 10.0.249.6
b=TIAS:64000
b=AS:64
t=0 0
m=audio 17170 RTP/AVP 0 101
a=ptime:20
a=fmtp:101 0-15
*May 24 17:39:44.149: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
BYE sip:0015195132407@10.0.249.6:5060;transport=tcp SIP/2.0
Via: SIP/2.0/TCP 10.0.6.30:5060;branch=z9hG4bKad2a27e009b9
Max-Forwards: 70
CSeq: 102 BYE
Reason: Q.850;cause=16
Content-Length: 0
*May 24 17:39:44.153: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Date: Fri, 24 May 2013 17:39:44 GMT
CSeq: 102 BYE
P-RTP-Stat: PS=0,OS=0,PR=1023,OR=175956,PL=0,JI=0,LA=0,DU=20
Content-Length: 0
*May 24 17:39:44.153: //23308/1C5ED7800000/SIP/Msg/ccsipDisplayMsg:
Sent:
BYE sip:0015195132407@85.88.5.233 SIP/2.0
Via: SIP/2.0/UDP 10.0.249.6:5060;branch=z9hG4bKB42C17D0
Max-Forwards: 70
Timestamp: 1369417184
CSeq: 103 BYE
Proxy-Authorization: Digest username="8686170390",realm="sip.dcalling.de",uri="sip:0015195132407@85.88.5.233",response="8d2c6d97ccbddaa1e012b0caee51832d",nonce="519fa6520000918f1307836b0bc16b901952bd5dcf08b348",algorithm=md5
P-RTP-Stat: PS=1023,OS=163680,PR=0,OR=0,PL=0,JI=0,LA=0,DU=20
Content-Length: 0
*May 24 17:39:44.653: //23308/1C5ED7800000/SIP/Msg/ccsipDisplayMsg:
Sent:
Max-Forwards: 70
CSeq: 103 BYE
Content-Length: 0
*May 24 17:39:44.781: //23308/1C5ED7800000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
Via: SIP/2.0/UDP 10.0.249.6:5060;rport=26664;received=216.16.231.94;branch=z9hG4bKB42C17D0
CSeq: 103 BYE
Content-Length: 0
*May 24 17:39:46.213: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Call-ID: 4326ecd3-57fd5583-d45d1@85.88.5.252
CSeq: 1 OPTIONS
Max-Forwards: 70
Content-Length: 0
*May 24 17:39:46.217: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
To: sip:216.16.231.94:26664;tag=51F40B78-65B
Date: Fri, 24 May 2013 17:39:46 GMT
CSeq: 1 OPTIONS
Content-Length: 0
*May 24 17:39:50.693: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 10.0.249.6:5060;branch=z9hG4bKB42D13D9
From: <>8686170390@sip.dcalling.de>;tag=51F41CF8-BC1
Date: Fri, 24 May 2013 17:39:50 GMT
Max-Forwards: 70
Timestamp: 1369417190
CSeq: 45607 REGISTER
Expires:  60
Supported: path
Content-Length: 0
*May 24 17:39:50.817: //23309/000000000000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
Via: SIP/2.0/UDP 10.0.249.6:5060;received=216.16.231.94;rport=26664;branch=z9hG4bKB42D13D9
Content-Length: 0
Received:
To: <>8686170390@sip.dcalling.de>;tag=c0b858c265d3be265092494badc524c3.bdb7
WWW-Authenticate: Digest realm="sip.dcalling.de", nonce="519fa66d000091d5b01b77da7ab436d0fb7dbfd83d5d60e9"
Content-Length: 0
*May 24 17:39:50.817: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 10.0.249.6:5060;branch=z9hG4bKB42E254E
Max-Forwards: 70
CSeq: 45608 REGISTER
Expires: 60
Authorization: Digest username="8686170390",realm="sip.dcalling.de",uri="sip:sip.dcalling.de:5060",response="c8eb4da55fd75388e9297c01c8dce65f",nonce="519fa66d000091d5b01b77da7ab436d0fb7dbfd83d5d60e9",algorithm=md5
Content-Length: 0
*May 24 17:39:50.941: //23309/000000000000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
Via: SIP/2.0/UDP 10.0.249.6:5060;received=216.16.231.94;rport=26664;branch=z9hG4bKB42E254E
Content-Length: 0
Received:
SIP/2.0 200 OK
To: <>8686170390@sip.dcalling.de>;tag=c0b858c265d3be265092494badc524c3.4aac
Content-Length: 0
2901-01.miovision.corp#terminal no monitor
Trace:
https://dl.dropboxusercontent.com/u/21916057/calllogs_00000019.txt.gz
https://dl.dropboxusercontent.com/u/21916057/SDL001_100_001156.txt.gz
conf t
voice service voip
sip
early-offer forced
Ok, so early-offer forced was already enabled.
I also had pass-thru content sdp enabled. And once that was removed, I have two-way audio! Appreciate you getting me on the right track with SDP.
Back to the topic of MTP's:
On CUCM's trunk configuration for the NA CUBE I've unchecked "Media Termination Point Required". I've checked the voice service voip|sip settings and they have early-offer forced as well, and no sdp pass-through but I have one issue:
Inbound calls have a very short life. I can call in (from my German trunk using NA DID) get the IVR, enter an extension, and the call will briefly display on my phone before it drops. If I call in from my cell phone to NA DID, I can get through the IVR, to my extension and connect but have no audio (connection stays up).
I'm guessing the German trunk provider isn't seeing any media so it drops the connection. I recieve this message on the Germany CUBE:
*May 25 15:53:10.871: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
BYE sip:500@216.16.231.94:39019 SIP/2.0
Via: SIP/2.0/UDP 85.88.5.252;branch=z9hG4bK1d75.6aa30751.0
Via: SIP/2.0/UDP 85.88.5.233:5060;received=85.88.5.233;branch=z9hG4bK21064c67;rport=5060
Max-Forwards: 69
From: <>0015195132407@sip.dcalling.de>;tag=as476855bd
To: "TESTING BRANCH" <>8686170390@sip.dcalling.de>;tag=56B8A2F4-2F5
Call-ID: 1C15D66-C48A11E2-8345E3B7-54AA1348@10.0.249.6
CSeq: 102 BYE
User-Agent: DCALLING PBX
X-Asterisk-HangupCause: Normal Clearing
X-Asterisk-HangupCauseCode: 16
Content-Length: 0
This seems like a NA CUBE -> IP phone issue now, seeing as I can get audio from the IVR, and send DTMF to interact with it.
