CISCO SX20 im looking for a supplier in Beijing
ReadersUK
Level 2
Level 2
Can anyone reccomend a VC supplier in the Beijing area? im looking to get a SX20 installed in a new office
regards
colin
admin11111
Level 4
Level 4
Hello Colin,
The best thing I can recommend is for you is to go to the following link:
http://tools.cisco.com/WWChannels/LOCATR/openAdvanceSearch.do
Then under the Authorized Technology Provider section.. choose a Telepresence ATP partner. And set the country for China. You should be able to find a partner by country AND just as importantly.. by region (which is China is almost as important as local language expertise).
John Kim
Worldwide Partner GTM- Telepresence
johnki2@cisco.com
