Cisco Telephony Sevice Provider on the ccmadmin administration page.
ranpierce
Level 6
Level 6
I would like to deploy the CiscoTSP and Wave Drivers to all the worksations in our company. I have installed it, configured it, and have it working fine on my workstation. However I do not want to have to do it manually on every workstation. Is there a way to get the CiscoTSP.exe in a msi format so I can push it out to all the workstations?
rlp
gogasca
Level 10
Level 10
Hi Randy,
Try the Web Administrator utility, this enables system administrators to create a One Click Install image of the Cisco IP SoftPhone installation on a web server.
Users can download this installation file (or install from the web), install Cisco IP SoftPhone on their client PCs, and begin using Cisco IP SoftPhone
without having to configure any settings.
Do you know off hand if I can just deploy the ciscotsp with this and not softphone?
I the reason I want the TSP is to be able to dial contacts from outlook and to choose a cisco phone you need to install the tsp. I do not want to install softphone on the workstations.
Thanks you have already been a lot of help.
rlp
