05-22-2012 08:35 AM - edited 03-16-2019 11:17 AM
Cisco Call Manager Version : 8.6.2.20000-2 (Locale Installer : cm-locale-tr_TR-8.6.2.1000-1.cop )
Cisco Unity Connection : 8.5.1.11900-21 (Locale Installer : uc-locale-tr_TR-8.5.1.1-16.cop)
This systems works together. We will upgrade Cisco CallManager(CUCM) to 8.6.2.21900-2 with cm-locale-tr_TR-8.6.2.1000-1.cop )
Cisco callmanager 8.6.2.21900-2 will be compatible with Cisco unity connection 8.5.1.11900-21 ?
Is there any decumantation to check this ?
Thanks.
Solved! Go to Solution.
05-22-2012 08:57 AM
Docs do not go to that detail, they just mention major versions and anything within that version is supported.
EDIT:
Cisco Unity Connection 2.x and Later
Any version of Cisco Unity Connection 2.x or later is supported for use with any version of Cisco Unified CM 4.1(3) or later.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
05-22-2012 08:37 AM
Yes, if you search CSC for the same topic you can find previous threads with the link.
http://www.cisco.com/en/US/docs/voice_ip_comm/connection/compatibility/matrix/cucsccpmtx.html
java
05-22-2012 08:43 AM
Thanks for your quick response. I have found that doc. But from this doc. I am not able to see detailed version.
For example 8.6.2.21900-5 ?
Is there any doc. to show detailed information.
05-22-2012 08:57 AM
EDIT:
java
05-22-2012 11:35 AM
Thanks.
It means that Cisco Unity Connection "8.5.1.11900-21" release will works with all Cisco UCM release 8.x .
