Cisco UCM upgrade to 11.5
experts,
I am looking for safest scenario & how long it takes  to upgrade following:
- 1 Pub and 4 Subs of Cisco UCM 10.5  ( include PLM 1.5) to 11.5
- 1 Pub and 1 Sub of Unity Connection 10.5 to 11.5
- 1 Pub and 1 Sub of Cisco CER 10.5 to 11.5
- 3 Cisco Media Sense server 10.5 to 11.5
- 2900, 3900 , VG204  , VG224
thanks,
K
Yes, with the caveat that any changes you did on 11.5 will be lost.
java
if this helps, please rate
6 Replies 6
Jaime Valencia
Start by looking at the compatibility info of each product in the target release to determine if you need to do it in a certain order, the  CUCM upgrade guide contains upgrade paths and provides estimates for various upgrade options.
java
Jamie,
If we upgrade UCM 10.5 to 11.5 and switch version to 11.5
when we see some issue, can we always go back to 10.5 ( switch version)  and no problem ?
K
java
do we need to worry on ITL or certs on 11.5 when we switch back to 10.5?
Certificates are handled at OS level.
java
so you mean switch back and forth partition between UCM 10.5 and 11.5 not an issue ?
