Cisco UCS - UCSC-C220-M3S
Jean Lofrano
Is there any matrix showing the relation between quantity of the users and UCS hardware?
For example: I want to know how many of the disk, memory  I need to configure a CUCM 8.0 on
UCSC-C220-M3S.
thanks.
If you need assistance getting the right HW and sizing for a new solution, reach pre-sales.
www.cisco.com/go/ph
Give them all the data and they'll tell you which servers you can use for that.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
6 Replies 6
Jaime Valencia
No, and there won't be, as you size that beforehand taking into account the OVA and products you'll use.
Unified Communications Virtualization Downloads (including OVA/OVF Templates)
http://docwiki.cisco.com/wiki/Unified_Communications_Virtualization_Downloads_(including_OVA/OVF_Templates)
java
java
Thanks, but the page does not open.
http://docwiki.cisco.com/wiki/Unified_Communications_Virtualization_Downloads_%28including_OVA/OVF_Templates%29
java
java
I need choose the best solution to create a HA with CCX, but the agents are in the remote site.
I have a UCS C220 M3S in the branch site and I´m thinking in create 2 virtual machines with CCX.
So I will have:
Branch site:
UCS C220 M3S with: 2 CUCM + 2 CCX
Remote site:
Agentes.
What do you think about this?
thanks,.
www.cisco.com/go/ph
java
java
Ok, thanks.
att.
