IP Telephony and Phones
Labels
Hi AllCould u please help me with 7941 phones, They are gving error after booting.below errors are blinking one after anotherError: Registring,Configuring CM list,updating CTLI tried factory reset with Soft reset(123456789*0#),Total hard reset(349167...
Rakesh K by Level 1
  • 283 Views
  • 0 replies
Resolved! CUCM redondancy
Hi,I have a Cisco IP telephony solution with 1x cucm Publisher (v8.5) and 2 subscribers. I need to add another box and set it up to act as the failover cucm for the publisher. Can this be done? If so any thought how to set it up?I dont need a 3rd sub...
Hello,This may be seen as a very basic question but is it possible on a per User basis (9971/7965) running Call Manager 8.5 to translate an inbound number eg 90791234567 into Blogs, Joe (Mobile) on the screen display?  I guess if you used LDAP and di...
Resolved! fxo issue
I have a customer who asked me for a speciacl request. The customer has 4 FXO on his gateway and his gateway is registered on CUCM.The customer asked me to define a FXO port from the four ports to him only ( he can do outgoing and incoming calls from...
Hello All,I have callmanager 7.0i have configured speed dial button on phone A to monitor phone BWhen phone B get connected in a call, the BLF button onphone A shows the busy icon.BUT when phone B is ringing the BLF button on phone A do not blink, i ...
Hello,I have a user that says her fingers are to fast and she want to turn off auto complete.  She says auto complete is causing her to mis-dial.  She has dialed 911 on more than a few occasions.  Her example was 9191xxx, 91 to get outside and long d...
                   Hello,can anyone point me to a hardware compatibility Matrix for CUC that lists all the versions?  I want to make sure we upgrade to the highest possible revision support on the servers we have.Thanks.  Replies rated.
Hello,We are facing a weird issue where our CUCM Publisher cannot boot up. I have already tried to repair the system through the Recovery Disk with no success.Find below the system messages:"Booting command-list root (hd0,0) Filesystem type is ext2f...
mflavio by Level 1
  • 714 Views
  • 4 replies
