Cisco Unified Attendant Console problem during installation
Zaher Juha
Dears
Platform Windows server 2012
Cisco Unified Attendant console 9.1
The problem before Database wizard when i click on next it gives me unable to connect to the server
Kindly find the attached screenshot
Aman Soi
Hi Zaher,
can u refer the link for
Installing SQL Server 2012
To install SQL Server 2012
http://www.cisco.com/c/dam/en/us/td/docs/voice_ip_comm/cucmac/10_0_1/install_admin/CUACA_web_admin_guide.pdf
Check if you are missing something.
regds,
aman
Thanks Aman
In the same installation file, it will install SQL server express 2008
but i'll check this
Hi Zaher,
in my case , it was reverse.Problem was resolved by using SQL express.
regds,
aman
Hi Aman,
When i faced this problem i tried to install an indepandant SQL server not the express and i did the same as mentioned under installing sql server 2012 for features i selected all of them and the same problem
