01-04-2011 01:08 AM - edited 03-16-2019 02:40 AM
Hi all
I get this message "cisco unified video advantage is not connected to any phone"
I enable the video capability and I changed my phone vlan to data vlan "my PC and Phone in the same vlan"The strange thing is IP Communicator is work fine, but still no connection between cuva and my phone.
I have CM 7, phone 7970, VT Camera iii and software cuva v2.1.1
Please guide me to sort out this issue.
Kaff
Solved! Go to Solution.
01-04-2011 04:04 AM
01-04-2011 01:20 AM
If I remember well, CUVA requires CDP to be enabled.
Is CDP enabled on the Switch ?
Pierre.
01-04-2011 01:33 AM
Check that the PC is connected to the switchport on the phone.
01-04-2011 02:15 AM
Appreciated your help,
CDP is enable in switch
The PC is connected to the PCport in the Phone. Yes and I already install IP communicator on PC is working fine
Akaff
01-04-2011 02:52 AM
What OS do you have on the PC?
01-04-2011 04:22 AM
Win XP.
02-28-2011 11:10 AM
Kaff,
Dunno if you got it working but check the phone configuration. Under Product Specific Configuration Layout make sure Video Capabilities is set to Enabled.
Rob
01-04-2011 04:04 AM
You can also try:
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a0080232626.shtml
Pierre.
02-28-2011 10:35 PM
Thank you all,
I thank this version software cuva v2.1.1 not support XP after I upgrade to win 7 it's working fine.
Thank you to everyone try to help me.
akaff
