Cisco Unity 4.x to Unity Connection 8.x Migration
rutledgec
We've recently had an outside vendor migrate our Unity 4 installation to a Unity Connection 8.x installation along with a Call Manager upgrade. Things went great but it was outside the scope of their work to decommission the old Unity 4 server. Are there any steps necessary to clean up our Active Directory environment before or after we decommission the server? Do we actually need to uninstall Unity before we power off the server and remove it?
Thanks!
Jaime Valencia
You can use the bunny killer to remove any Unity properties they might have in AD,  but other than that, CUC/CUCM won't mess with the AD itself so, assuming you already have all the VM profiles, call handlers, AA, etc pointing to CUC you can safely turn it down and delete any remaining Unity configs from CUCM (if any are left).
No real need to uninstall Unity, you can just power it off.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Jaime Valencia
java
java
