11-20-2012 12:51 PM - edited 03-16-2019 02:18 PM
I have a doubt. How to work the Unity Connection with viewmail and how to know the step by step to configure this.
TIA
Cristian.
11-21-2012 10:38 AM
Help...!!
12-01-2012 08:23 AM
You'll generally get a better response the more specific your question is and the more it sounds like you've already read the product documentation. We're all pitching in for free so answers that take more than a few minutes to type are rare unless it's an interesting topic. With that in mind:
ViewMail for Outlook (VMO) is supported by Unity Connection out of the box. You can install or deploy it on user workstations and either use IMAP (user Class of Service must allow this) or Single Inbox, which is recommended but be aware of SMTP domain considerations, to access the messages. As of VMO 8.6(5)+ users may not have to enter their credentials when using Single Inbox which helps with scalability.
Please remember to rate helpful responses and identify helpful or correct answers.
12-05-2012 06:19 AM
Dear Jonathan
I was referring to a setup guide, step by step to enable the view mail service and any diagram where explain the
interacts between outlook user-viewmail for outlook-IMAP(if optional or not)-unity connection-exchange.
- For Single Inbox feature, you must enable the IMAP service?
TIA
Cristian.
