Cisco Unity Connection 8.6.(2a)SU3 boot.bif required
Bhavani Sankar
Hi All,
I require "boot.bif" file for Cisco Unity Connection 8.6.(2a)SU3 to make the DVD as bootable.
Thank you in advance.
Sankar.
Hi Sankar.
If you have any bootable image (even CUCM) you can generate it using EG. Ultraiso and than recreate it within a non-bootable image to make it bootable
Carlo
Please rate all helpful posts "The more you help the more you learn"
Hi Sankar.
Carlo
