Hi aokanlawon
I contacted the TAC, and they confirmed that this is a BUG :
CUC:Import Users: Users with tkuserprofile value of 3 should be hidden
CSCuj67907
Description
Symptom:
While trying to Import users a Token user is listed.
Example of a Token User - Token_User_f30e7d6f-9fb9-4aff-8279-1b88b1d0aaf0
Conditions:
Unity Connection 9.x and higher.
Workaround:
N/A
Further Problem Description:
The Import Users page lists entries from the End User table.
Normal users have a tkuserprofile value of 1. Token users have a tkuserprofile value of 3. Users with a tkuserprofile value of 3 are hidden users and should not be displayed on the GUI.
The solution is to install service releases
Thank you very much for your help.
Younes CHAFI.
