Cisco unity Express installation
hello, I'm trying to install Cisco Unity Express software on the ISM-SRE-300-K9 on a 2951 router
when i issue a service-module sim 0/0 status this is what i get
service module is cisco ism 0/0
service module supports session via tty line 195
service module is failed
service module heart-reset is enabled
service module is in fail open
service moodule status is not available
no install/uninstall in progress
could you please help me out, i need to be able to install cue on this module
thanks
Cris
35 Replies 35
did you do a no sh on the ser 0/1 ?
is 192.168.254.X routable ?
Hello Cris,
I did a no shut yes. Take a look:
Router#sh int servi
Router#sh int service-Engine 1/0
Service-Engine1/0 is up, line protocol is up
  Hardware is I82559FE, address is 0013.c41a.ba90 (bia 0013.c41a.ba90)
  Internet address is 192.168.254.1/30
  MTU 1500 bytes, BW 100000 Kbit/sec, DLY 100 usec,
  Keepalive set (10 sec)
  Last input 01:13:31, output 00:00:02, output hang never
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
     0 packets input, 0 bytes, 0 no buffer
     Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
     572 packets output, 59220 bytes, 0 underruns
     0 output errors, 0 collisions, 1 interface resets
     0 unknown protocol drops
     0 lost carrier, 0 no carrier
Router#
The network 192.168.254.X/30 was created by me to establish a point-to-point network between the service module and the router. Is that a problem?
Karl
No need to get creative with addressing for the CUE. Use the recommended tecnique of unnumbered to LAN and static /32 route.
After, you do service module connect and check what's happening.
Paolo,
I did it already, the unnumbered way is currently running, but I still got no answer - not able to telnet the module.
Thanks for replying!
Karl
Check config under line xx -  likey something is wrong there.
I did not understand you point. Could you explain it again? (Line XX?)
If you look at your config there is a section for asynch lines (TTY 66 in your case) and you got to have configured it right in order to access CUE console.
The same is also explained in the CUE manuals.
Paolo,
I'm sorry but I could not find any info about how to access using the async line. Could you help me with that too?
Karl
Hi, I think you really have to read again my answer above, and the CUE installation manual too.
Maybe I did not expressed me well. I looked at some manuals I have here but I did not find the info you talked about. I understand there is a config to do in the async line, but as far as I read, my config seems to be ok (at least for this line).I thought you could have this info in hands, so you could paste it here. Anyway, thanks for replying!
To diagnose problems, not only you have to post your configs, but also logs of when you try to do something, and some message is received.
Otherwise it becomes a psychic reader matter.
I think know it's your time to read my message above.
I pasted logs, configs e errors messages.
Can you find it?
I'm sending again, jsut to facilitate:
interface Loopback0
ip address 192.168.254.1 255.255.255.0
interface Service-Engine1/0
ip unnumbered Loopback0
service-module ip address 192.168.254.2 255.255.255.0
service-module ip default-gateway 192.168.254.1
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 189.125.7.13
ip route 192.168.254.2 255.255.255.255 Service-Engine1/0
line 66
no activation-character
no exec
transport preferred none
transport input all
transport output lat pad telnet rlogin lapb-ta mop udptn v120 ssh
Router#show int service-Engine 1/0
  Interface is unnumbered. Using address of Loopback0 (192.168.254.1)
  Last input 21:07:59, output 00:00:04, output hang never
     9771 packets output, 1012637 bytes, 0 underruns
     0 output errors, 0 collisions, 2 interface resets
Router#
Router#service-module service-Engine 1/0 status
Service Module is Cisco Service-Engine1/0
Service Module supports session via TTY line 66
Service Module is waiting for registration message
Service Module status is not available
Router#ping 192.168.254.1
Sending 5, 100-byte ICMP Echos to 192.168.254.1, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/1/4 ms
Router#ping 192.168.254.2
Sending 5, 100-byte ICMP Echos to 192.168.254.2, timeout is 2 seconds:
Success rate is 0 percent (0/5)
I think it's better to see know. All the info together. The message "Service Module is waiting for registration message" is new for me. The last time I got this display, in its place I got a message as: "Service Module failed"
Any tips?
thanks,
Karl
As mentioned before, you should use "ip unnumbered" with a LAN address, not loopback.
Then post a log when doing service-module session.
Paolo,
I attached a show running-config, so you see the whole config. The displays are here:
Service Module is failed
Router#service-module service-Engine 1/0 session clear
[confirm]
[OK]
Trying 172.20.4.30, 2066 ... Open
And nothing else happens. It stays at this status "Trying..."
I also changed the config to unnumbered pointing to Gigaethernet port. Is it right? Any tips?
Karl
