Cisco unity express smtp settings problem after reload
i have a CUE with version 3.2.1, i'm experiencing a problem with the smtp settings, i changed the smtp server in the infrastructure, so i changed the ip address in the smtp settings in the CUE, all works properly until reboot.
After reboot, the CUE doesn't retain the smp settings and come out the old.
Is it a bug?
Thank you in advance.
paolo bevilacqua
If using CLI, do "write".
If using GUI, control panel - save configuration.
paolo bevilacqua
Thank you very much Paolo, I can not telnet so I used the gui, i don't much use the gui.
You're welcome, thanks for the nice rating and good luck!
