Cisco VG204 configuration issue
sinuksml1
hi,
I am using Aastra MX-One as PBX and it is connected to cisco VG204 and attached the topology here
I have a issues on phone calls. I can’t make call from cell phone  to analog phone (Cisco VG204/224 ). However, I can make it, but it depends. After continuous calling it , will work… without dial tone signal about 10 seconds, it is not full.
But, when I call from cell phone to IP-phone or analog phone (Aastra ) there is no problems. there is have dial tone signal and the signal about 35 seconds, it is full.
and when I call from external analog phones to analog phone (Cisco VG204/224) there is no problem on call, but there is have dial tone signal and the signal about 10 seconds, it is not full.
Just i need to check is there any missing configuration in vg204 side
my vg 204 configuration backup
VG204-MainSubstation#show running-config
Building configuration...
Current configuration : 4600 bytes
! Last configuration change at 14:42:23 UTC Sun Jun 30 2002
version 15.3
no service pad
hostname VG204-MainSubstation
boot-start-marker
boot-end-marker
enable password XXXX
no aaa new-model
no process cpu extended history
no process cpu autoprofile hog
no ip domain lookup
ip cef
no ipv6 cef
voice service pots
voice service voip
sip
bind control source-interface FastEthernet0/0
bind media source-interface FastEthernet0/0
session transport tcp
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g729br8
voice-card 0
application
service dsapp
param callWaiting TRUE
global
service default dsapp
ip address x.x.x.x 255.255.0.0
duplex auto
speed auto
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
ip forward-protocol nd
no ip http server
ip route x.x.x.x  x.x.x.x x.x.x.x
no service-routing capabilities-manager
dialer-list 1 protocol ip permit
control-plane
voice-port 0/0
station-id name "Electrical2 MSS"
station-id number 7246
caller-id enable
voice-port 0/1
station-id name MSS-7247
station-id number 7247
caller-id enable
voice-port 0/2
voice-port 0/3
mgcp modem passthrough voip mode nse
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
dial-peer voice 7246 pots
destination-pattern 7246
progress_ind alert enable 8
progress_ind progress enable 8
progress_ind connect enable 8
port 0/0
dial-peer voice 7247 pots
destination-pattern 7247
port 0/1
dial-peer voice 100 voip
description link-to-PABX
destination-pattern 7...
session target ipv4:x.x.x.11
voice-class codec 1
dtmf-relay rtp-nte
dial-peer voice 9 voip
description link-to-PSTN
destination-pattern 9[1-9]T
voice-class codec 1
dtmf-relay rtp-nte
dial-peer voice 7238 voip
description link-to-A-extension-RIB-A
destination-pattern 723[8-9]
session target ipv4:x.x.x.14
voice-class codec 1
dtmf-relay rtp-nte
dial-peer voice 7280 voip
destination-pattern 728[0-1]
voice-class codec 1
dtmf-relay rtp-nte
dial-peer voice 7282 voip
description link-to-A-extension-RIB-B
destination-pattern 728[2-3]
session target ipv4:x.x.x.16
voice-class codec 1
dtmf-relay rtp-nte
dial-peer voice 7248 voip
description link-to-A-extension-UtilitySub
destination-pattern 724[8-9]
session target ipv4:x.x.x.17
voice-class codec 1
dtmf-relay rtp-nte
dial-peer voice 7250 voip
destination-pattern 7250
voice-class codec 1
dtmf-relay rtp-nte
dial-peer voice 7251 voip
description link-to-A-extension-Canteen
destination-pattern 725[1-4]
session target ipv4:x.x.x.18
voice-class codec 1
dtmf-relay rtp-nte
dial-peer voice 7255 voip
description link-to-A-extension-CCR
destination-pattern 725[5-8]
session target ipv4:x.x.x.19
voice-class codec 1
dtmf-relay rtp-nte
dial-peer voice 7259 voip
description link-to-A-extension-LAB
destination-pattern 7259
session target ipv4:x.x.x.21
voice-class codec 1
dtmf-relay rtp-nte
dial-peer voice 7260 voip
destination-pattern 726[0-1]
voice-class codec 1
dtmf-relay rtp-nte
dial-peer voice 7262 voip
description link-to-A-extension-MWS-GarageB
destination-pattern 726[2-9]
session target ipv4:x.x.x.22
voice-class codec 1
dtmf-relay rtp-nte
dial-peer voice 7230 voip
description link-to-A-extension-Chemical
destination-pattern 7230
session target ipv4:x.x.x.23
voice-class codec 1
dtmf-relay rtp-nte
dial-peer voice 7231 voip
description link-to-A-extension-FFO-CCB
destination-pattern 723[1-5]
session target ipv4:x.x.x.24
voice-class codec 1
dtmf-relay rtp-nte
dial-peer voice 7236 voip
description link-to-A-extension-warehouse
destination-pattern 727[6-7]
session target ipv4:x.x.x.25
voice-class codec 1
dtmf-relay rtp-nte
line con 0
no modem enable
line aux 0
line vty 0 4
privilege level 15
password XXXX
login
transport input all
end
0 Replies 0
