Cisco Voice Gateway with SIP Digium Switchvox interoperability!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
12-08-2014 06:22 AM - edited 03-17-2019 01:15 AM
Project scenario to replace the existing ISDN/PRI PBX with Digium switchvox SIP PBX.
1) **Existing working system is PRI PBX --------Cisco IOS Gateway -------MPLS-----VZB SBC.
New scenario:
2) SIP PBX Digium Switchvox--------- Cisco IOS Gateway ----------MPLS -------VZB SBC.
Change made to replace the PRI dial-peer:
===================Dial-peer to VZB side=====================
dial-peer voice 100 voip
description OUTBOUND Voice SIP calls
translation-profile outgoing DIGITSTRIP-9
destination-pattern 9T
rtp payload-type nte 98
session protocol sipv2
session target sip-server
voice-class codec 1
voice-class sip early-offer forced
voice-class sip bind control source-interface GigabitEthernet0/1
voice-class sip bind media source-interface GigabitEthernet0/1
dtmf-relay rtp-nte
no vad
dial-peer voice 400 voip
description voip dial peer - from proxy
incoming called-number .T
voice-class codec 1
dtmf-relay rtp-nte
ip qos dscp cs5 media
ip qos dscp cs3 signaling
no vad
=========================== Dial-peer pointing to Digium Switchvox side =========================
dial-peer voice 500 voip
description switchvox
preference 1
destination-pattern 526788….
session target ipv4:10.x.x.x
session transport tcp
voice-class codec 1
voice-class sip bind control source-interface GigabitEthernet0/2
voice-class sip bind media source-interface GigabitEthernet0/2
dtmf-relay rtp-nte
dial-peer voice 550 voip
preference 1
incoming called-number 526788….
voice-class codec 1
dtmf-relay rtp-nte
no vad
Result after the change-
1) Out going call works successfully without issues both signaling and media.
Problem-
2) Incoming call fails on the Digium switchvox after 407 challenge from the digium switchvox. The digium log shows the failure reason is unknown source that tells it was failing the failing during 407 challenge.
Question- Can we configure the Cisco IOS gateway (C2911) to receive the 407 challenge and replay with another re-invite with nounce value or blank?
- Labels:
Other IP Telephony
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
12-08-2014 06:26 AM
Can you post a debug ccsip messages from the CUBE? Include calling and called number. Can you also attach the sip log from the PBX?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
12-08-2014 01:35 PM
I will do more test tonight and update this post. Digium mightn't allow us disabling the digest authentication for security reason. I am thinking also to include another change on the sip configuration on Cisco gateway "header-passing error-pass through" to send the 407 challenge to the service provider and hope they will respond with another re-invite.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
12-09-2014 08:33 AM
Ayodeji- For some reason the ccsip debug all/calls wasn't showing the call flow. I have tried to configure "header-passing error-pass through" but no luck because it isn't supported on C2911 IOS 15.0. I will do more research at this point or work directly with the provider to bypass this gateway as it is with limited capabilities.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
12-08-2014 06:28 AM
Is it working if you disable digest authentication in Digium?
Vivek
