Bookmark
Subscribe
3456
Cisco Web Service not running[CDR]
eran moyal
Hello ,
I have problem with CDR I can't access web.
I try to perform reset to Cisco Web Service in CUCM but service still stuck not running .
my version of CUCM 11.5.1.12900-21.
any idea?
9 Replies 9
Hello Eran,
Could you provide a "utils service list" on the publisher CLI?
Regards, Jaime.
Requesting service status, please wait...
System SSH [STARTED]
Cluster Manager [STARTED]
Name Service Cache [STARTED]
Entropy Monitoring Daemon [STARTED]
Cisco SCSI Watchdog [STARTED]
Service Manager [STARTED]
HTTPS Configuration Download [STARTED]
Service Manager is running
Getting list of all services
>> Return code = 0
A Cisco DB[STARTED]
A Cisco DB Replicator[STARTED]
Cisco AMC Service[STARTED]
Cisco AXL Web Service[STARTED]
Cisco Audit Event Service[STARTED]
Cisco Bulk Provisioning Service[STARTED]
Cisco CAR DB[STARTED]
Cisco CAR Scheduler[STARTED]
Cisco CAR Web Service[STOPPED]  Component is not running
Cisco CDP[STARTED]
Cisco CDP Agent[STARTED]
Cisco CDR Agent[STARTED]
Cisco CDR Repository Manager[STARTED]
Cisco CTIManager[STARTED]
Cisco CTL Provider[STARTED]
Cisco CallManager[STARTED]
Cisco CallManager Admin[STARTED]
Cisco CallManager SNMP Service[STARTED]
Cisco CallManager Serviceability[STARTED]
Cisco CallManager Serviceability RTMT[STARTED]
Cisco Certificate Authority Proxy Function[STARTED]
Cisco Certificate Change Notification[STARTED]
Cisco Certificate Expiry Monitor[STARTED]
Cisco Change Credential Application[STARTED]
Cisco DHCP Monitor Service[STARTED]
Cisco DRF Local[STARTED]
Cisco DRF Master[STARTED]
Cisco Database Layer Monitor[STARTED]
Cisco Dialed Number Analyzer[STARTED]
Cisco Dialed Number Analyzer Server[STARTED]
Cisco DirSync[STARTED]
Cisco Directory Number Alias Lookup[STARTED]
Cisco Directory Number Alias Sync[STARTED]
Cisco E911[STARTED]
Cisco ELM Client Service[STARTED]
Cisco Extended Functions[STARTED]
Cisco Extension Mobility[STARTED]
Cisco Extension Mobility Application[STARTED]
Cisco IP Manager Assistant[STOPPED]  Component is not running
Cisco IP Voice Media Streaming App[STARTED]
Cisco Intercluster Lookup Service[STARTED]
Cisco License Manager[STARTED]
Cisco Location Bandwidth Manager[STARTED]
Cisco Log Partition Monitoring Tool[STARTED]
Cisco Prime LM Admin[STARTED]
Cisco Prime LM DB[STARTED]
Cisco Prime LM Server[STARTED]
Cisco RIS Data Collector[STARTED]
Cisco RTMT Reporter Servlet[STARTED]
Cisco SOAP - CDRonDemand Service[STARTED]
Cisco SOAP - CallRecord Service[STARTED]
Cisco Serviceability Reporter[STARTED]
Cisco Syslog Agent[STARTED]
Cisco TAPS Service[STARTED]
Cisco Tftp[STARTED]
Cisco Tomcat[STARTED]
Cisco Tomcat Stats Servlet[STARTED]
Cisco Trace Collection Service[STARTED]
Cisco Trace Collection Servlet[STARTED]
Cisco Trust Verification Service[STARTED]
Cisco UXL Web Service[STARTED]
Cisco Unified Mobile Voice Access Service[STARTED]
Cisco User Data Services[STARTED]
Cisco WebDialer Web Service[STARTED]
Host Resources Agent[STARTED]
MIB2 Agent[STARTED]
Platform Administrative Web Service[STARTED]
SNMP Master Agent[STARTED]
SOAP - Diagnostic Portal Database Service[STARTED]
SOAP -Log Collection APIs[STARTED]
SOAP -Performance Monitoring APIs[STARTED]
SOAP -Real-Time Service APIs[STARTED]
Self Provisioning IVR[STARTED]
System Application Agent[STARTED]
Cisco Prime LM Resource API[STOPPED]  Service Not Activated
Cisco Prime LM Resource Legacy API[STOPPED]  Service Not Activated
Cisco Wireless Controller Synchronization Service[STOPPED]  Service Not Activate
Primary Node =true
Please run "utils service start Cisco CAR Web Service" wait 5 minutes and provide me the output.
Regards, Jaime.
I have problem with command :
admin:utils service start Cisco CAR Web Service
Executed command unsuccessfully
Invalid service name for start/stop, valid names are:
   System SSH
   Cluster Manager
   Name Service Cache
   Cisco SCSI Watchdog
   Service Manager
   Service Manager
   A Cisco DB
   Cisco CAR DB
   Cisco DRF Local
   Cisco DRF Master
   Cisco Prime LM DB
   Cisco Tomcat
   SNMP Master Agent
Hello Eran,
Hmm i thought it could be started from the CLI.
Oh Well, please go to the CUCM Web GUI > Serviceability > Tools > Service Activation > Look for Cisco CAR Web Service and start the service.
Regards, Jaime.
the service is activate but status  not running after I press start .
Please go to RTMT > Trace and Log Central > Collect Files > Select Cisco CAR Web Service for the publisher > click next > on second page select Service Manager for the publisher > next next until the last page is reached > select relative range and the last hour > download the traces zip them and attach them here so i can take a look.
Regards, Jaime.
sorry for delay .
this is log :
07:47:06.563 |servMgdProc::gracefulRestart - Cisco CAR Web Service : Start phase in Restart returned 0
07:47:06.563 |servMMgdWebApp::checkState(): CurState (notRunning), DesiredState (running) - Service : Cisco CAR Web Service
07:47:06.563 |servMDataMgr::isActive(): node 9 DEP_ACTIVE Cisco CAR Web Service
07:47:06.563 |servMMgdWebApp::createProc(): Service - Cisco CAR Web Service
07:47:06.565 |servMMgdWebApp::checkState():  Start ret: 0
07:47:06.565 |servMProcThreadMain :receiveMessage:length:28
07:47:06.565 |servMProcThreadMain : Processing START request
07:47:06.567 |executeTomcatCommand() : for Service - Cisco CAR Web Service, http_source - /manager/text/start?path=/car, port : 0
07:47:06.567 |servMHttpApi::sendReq():port:8080 - m_listPort:0
07:47:06.572 |servMHttpApi::sendReq(): ret buffer of len=174=a3
FAIL - Application at context path /car could not be started
FAIL - Encountered exception org.apache.catalina.LifecycleException: Failed to start component [/car]
07:47:06.665 |servMProcThreadMain :Inside-While-loop
07:47:07.565 |servMMgdWebApp::handleAsyncResponse(): Cisco CAR Web Service failed to start with ret=1071
07:47:07.565 |servMProc::setCurState() CurState (notRunning) for service - Cisco CAR Web Service
07:47:07.567 |servMMgdWebApp::handleAsyncResponse(): START failed with ret=1071
07:47:07.567 |servMMgdWebApp::checkState(): CurState (notRunning), DesiredState (running) - Service : Cisco CAR Web Service
07:47:07.567 |servMMgdWebApp::checkState():  Scheduling restarts ret
Hi Eran,
The fix for this issue based on the information that you have just provided will most likely require a root account procedure.
Please open a case with Cisco TAC and provide the following error message in the case:
I don't think there is any further troubleshooting i could provide.
If you don't have access to open cases with Cisco TAC, your best bet would be to rebuild the publisher.
Regards, Jaime.
