Clarification of dail peers working on H.323 or SIP Trunk
prakashsatya
How dialpeers work for h.323 or sip GW/trunk for incoming and outgoing calls .
what is the call flow in terms of SIP and H.323 for an Incoming and outgoing calls.
how dailpeers comes in to the Picture .
as i know call manager will not come in to the picture when using sip or h.323 call routing , call routing needs to done using dial peers . as cucm has no control over SIP and H.323 call control .
Any Help is appreciated .
-Satya
Google is the answer to your queries. Here you go, find the below link helpful
https://www.cisco.com/c/en/us/support/docs/voice/call-routing-dial-plans/14074-in-dial-peer-match.html
Abhay Singh Reyal
The Only Way To Do Great Work Is To Love What You Do. If You Haven’t Found It Yet, Keep Looking. Don’t Settle
Jaime Valencia
Plenty of documentation on the topic
https://www.cisco.com/c/en/us/td/docs/ios/12_2/voice/configuration/guide/fvvfax_c/vvfpeers.html
java
if this helps, please rate
