Rout list registered with subscriber
waqas sardar
Hi Team
We have publisher and three subscriber. Rout list is registered with third subscriber only. I restarted route list but no luck.
6 Replies 6
Ratheesh Kumar
Hi there
Check the Cisco Unified Communications Manager Group in your Route List. May be the Sub3 is the first priority in your CUCM Group.
Hope this helps!
Cheers
Rath!
***Please rate helpful posts***
@Ratheesh Kumar  third subscriber is on last priority in cm group.
- Reset the Route List
- Do the diagnostic test from CLI and see if there is any issue.
- Create a TEST CM group with only on CM server in it and see if it gets registered with that node to which you want this to get registered with.
- Try deleting and adding it again.
- Is still there is an issue check the replication status
Abhay Singh Reyal
The Only Way To Do Great Work Is To Love What You Do. If You Haven’t Found It Yet, Keep Looking. Don’t Settle
Sounds more like a DB issue. Please check the status.
Does “Run all Nodes” makes a difference to you.
Hope this helps
Cheers
Rath!
@Ratheesh Kumar
unchecked "Run all Nodes" solved the issue but why it append ?
Basically what happens when you check the "Run on all Active CM nodes", With this The RL will register with server having highest with highest CTI ID/node id. In those case the CM Group priority is not coming into picture. is
Hope this Helps
Cheers
Rath!
