Clear an ISDN 30 Voice Channel after X minutes of silence?
Dominic Ellis
Is there a command that can be used automatically clear a ISDN30 Voice channel
after x minutes of silence. This is for a H323 Cisco VGW 3845.
The past problem we have had is that a couple of calls have not cleared when hung up.
Rather that going through the long process of an Argument with the Telecoms provider
it would be better to be able to put a command on the VGW that would stop the problem
happening in the first instance.
Dominic
Thanks for reply - exactly what I needed.
dominic
Thank you for the nice rating and good luck!
