Client Matter Code and Call Forwarding
bkhanal1971
Level 3
Level 3
Hi Experts:
We use CMC codes for tracking long distance calls. All long distance route patterns are configured to prompt for the code. However, when somebody tries to setup "call forward all", in their phones, it does not take the numbers with prefix 1.
So, is there anyway that we are prompted to enter the code when we setup the call forwarding all option in the phone? It works great if I enter local numbers though. I am using UCM 8.6
Thank you for your help.
Jaime Valencia
No, you need RPs without CMC for CF.
Create a separate set of RPs for that and then adjust the CF CSS policy and CSS's as required
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Thank you! Appreciate your prompt response.
