Mobile Connect on 8961
Brett Williston
I have successfully configured mobile connect on an 8961 but a soft key for "mobility" is not appearing on the 8961. So the user has no way of turning it on and off. How do I get this soft key to appear?
Hey Brett,
No worries my friend
It will be a Phone Button template. See below for steps;
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/8_6_1/ccmcfg/b06phtmp.html#wpxref58098
If you find the existing Button template you can copy/rename it and then you will be able to
add a Mobilty button on the newly named/created template. Once that's done apply the
new template to the specific 8961 and you should be good to go.
***You can't modify the Standard templates***
Cheers!
Rob
"go easy...step lightly...stay free "
- The Clash
5 Replies 5
Rob Huffman
Hi Brett,
For the 8961 you would need to program a Feature button instead of a Softkey
Feature Buttons and Softkeys
Table 7-4 provides information about some of the features that are available on  softkeys, some that are available on dedicated feature buttons, and some  that you need to configure as programmable feature buttons. An "X" in  the table indicates that the feature is supported for the corresponding  button type or softkey. Of the two button types and softkeys, only  programmable feature buttons require configuration in Cisco Unified IP  Phone administration.
Note The  Cisco Unified IP Phone 8961, 9951, and 9971 does not use softkey  templates in Cisco Unified Communications Manager administration.
For information on configuring programmable feature buttons, see the "Modifying Phone Button Templates" section.
Table 7-4     Features and Corresponding Buttons and Softkeys
Feature Name
Dedicated Feature Button
Programmable Feature
Button
Softkey
All Calls
X
Answer
X
X
Call Back
X
X
Call Forward All
X
X
Call Park
X
X
Call Park Line Status
X
Call Pickup
X
Call Pickup Line Status
X
Conference
X
X
(available while on a conference only)
Divert
X
Do Not Disturb
X
Group Pickup
X
Hold
X
Hunt Groups
X
Intercom
X
Malicious Call Identification (MCID)
X
Meet Me
X
Mobile Connect
X
Mute
X
Other Pickup
X
Privacy
X
Redial
X
X
Speed Dial
X
X
Speed Dial Line Status
X
Transfer
X
X
(available during a transfer only)
Quality Reporting Tool (QRT)
X
http://www.cisco.com/en/US/docs/voice_ip_comm/cuipph/9971_9951_8961/7_1_3/english/admin/guide/9971usr.html#wp1087800
Cheers!
Rob
- The Clash
Brett Williston
Thanks Rob. I'm a newbie. How do I program a feature button? Do I need to configure a phone template?
Hey Brett,
Cheers!
Rob
- The Clash
Thanks again Rob! Worked perfectly. 5 stars!
Rob Huffman
Hi Brett,
Good stuff! Glad to be of some small help here
Cheers!
Rob
- The Clash
