Client matter code Timer before User dial the CMC codes
lfriedemann
Hello guys..
We are trying to use the CMC here. But the users are complaing about the time to insert the CMC code.... is too short.
We know about T302 After the CMC code is inserted... and The users can use #... that ´s not the issue....neither the complaints
But we still have the complaints about before the code was inserted... too short...
Somebody knows some Parameter where we can increase that TIMER ???
Tks for while !!!
5 Replies 5
Hi.
The time available for users to insert the CMC is exactly the T302 timer.
So, modify that timer to get more time.
Carlo
Please rate all helpful posts "The more you help the more you learn"
Hi Carlo... Tks for the aswer... But I´m not talking about this time...
I´m talking about the timer before the User makes the decision what CMC code does he need to insert there....
Hi.
Me too :)
Is the T302 timer that is used there.
Cheers
Carlo
Carlo is correct, the only timer, from all the ones available, that affects CMC, is T302, there are no other timers.
java
if this helps, please rate
haha... ok.. if we don´t have another timer for that... is default 3 seconds... but t302 timer is just for after the user makes the decision and dialed the number... :)
Tks Guys...
