clustering question
thomasmphil123
hai all, am new to iptelephony and i have some doubts to clear ..experts plz do help.my questns are
1.what all types of data bases are there in CM and how they replicate
2. what is the default LDAP in CM
3. what kind of data is collected by subscriber that is synched with publisher when it comes online.
4. what all services will not work if the pub is down.
SQL 2000 DB, transactional replication mode
DC directory
SDL, RIS, SQL
services on SUBs will keep running, no changes whatsoever allowed due to DB lockdown
java
if this helps, please rate
java
Jaime Valencia
many of those questions depends on what version you're talking about so about which version you want info?????
java
java
ccm 4.1 is d version am using.thankyou
DC directory
SDL, RIS, SQL
java
java
thank u javalenc.That was very much informative.
