IP Telephony and Phones
Labels
I'm having a memory cramp here and want to make sure that I'm thinking on the right lines here. I'm upgrading a customer from 4.x to 6.x, I've already verified the server is supported, memory, HD's, so we're good there. The customer has a PUB and S...
Hi allI am simulating a failure on our UC 6 system, and the IP Phones have successfully gone into CM Fallback Service Operating mode. However, when I dial a number, it only accepts 4 digits and then tries to set up the call.Below is the config:call-m...
Hi AllHaving 2 problems with Unity.The first, when calling into voicemail from an IP Phone, it says the messaging store server is offline, and will be able to access messages after the outage has cleared. Checked on Unity and do not see any errors. I...
Hi i'm using the pound(#) to terminates interdigit timeout when i'm making a call but i want to terminate the interdigit timeout without the pound(#). Where can i reduce this timing, i have already reduced T302 to 3.5 seconds ( on my CCM6).Thanks.
during SRST, let us say, i have 3 phones with DN 1001, 1002, 1003.2 questions,1, on the IP phone, is the CFwdAll softkey show up or not? if not, how can I call forward all?2, if 1001 forward all call to 1002, can 1003 call 1001? (fast busy or forward...
Hi netprotians,Can I ask if anyone has tried connected IP phones or ATA to a DC power supply.From the Phone data sheet (E.g 7945 link below), it mentions that the power cube is a AC power supply and not able to connect to DC. But would anyone know if...
I installed a new T1 card (HWIC-1CE1T1-PRI)to Cisco 2821 (having CME running on it). The router didn't recognize the card.They first told me that i need to have DSP module (PVDP) installed. After i confirmed that it's installed they said i need a re...
Hi Guys,I just configured a H.323 gateway in Brasil, it works fantastically outbound, but the in bound calls get to the call manager only to receive the error message "check the number you dialed, blah, blah". I know this is a CM error as it's in Eng...
wrickk_2 by Level 1
  • 411 Views
  • 2 replies
