01-11-2011 08:34 AM - edited 03-16-2019 02:48 AM
Good day Friends.
So,i've finished (as i think) with UCCX settings and now solving some problems with inbound and outbound PRI calls.
Is it possible to manage pri channels?
For example,10 chanells to Agents,2 to some cust. division and etc.
Now what i have is couple of translation patterns on ccm for test calls to IVR and one IP phone.
When i'm making out call i get busy tone.
According to DNA-everything is ok.
Debug isdn q931:
*Jan 11 16:32:26.373: ISDN Se1/0:15 Q931: TX -> SETUP pd = 8 callref = 0x0001
Sending Complete
Bearer Capability i = 0x8090A3
Standard = CCITT
Transer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA9839F
Exclusive, Channel 31
Calling Party Number i = 0x2181, '4377900'
Plan:ISDN, Type:National
Called Party Number i = 0x80, '4390828'
Plan:Unknown, Type:Unknown
*Jan 11 16:32:26.449: ISDN Se1/0:15 Q931: RX <- RELEASE_COMP pd = 8 callref = 0x8001
Cause i = 0x829F - Normal, unspecified
CC_GW_1#
Is this telco problem or mine?
I cann't see dial-peers for my E1 port also.
Here is config...
Building configuration...
Current configuration : 2541 bytes
version 12.3
downward-compatible-config 1.1
service password-encryption
hostname CC_GW_1
boot-start-marker
boot-end-marker
card type e1 1 1
logging buffered 51200 warnings
enable secret 5 $1$FmaJ$Q.DLcCN9e07iae2lO5m0p/
enable password 7 045209071C385F
no network-clock-participate slot 1
no aaa new-model
ip subnet-zero
ip cef
isdn switch-type primary-net5
voice-card 0
no dspfarm
voice-card 1
no dspfarm
ccm-manager fallback-mgcp
ccm-manager redundant-host 10.30.1.2
ccm-manager mgcp
ccm-manager music-on-hold
ccm-manager config server 10.30.1.1
ccm-manager config
controller E1 1/0
framing NO-CRC4
pri-group timeslots 1-31 service mgcp
controller E1 1/1
shutdown
framing NO-CRC4
interface GigabitEthernet0/0
description $ETH-LAN$$ETH-SW-LAUNCH$$INTF-INFO-GE 0/0$
ip address 10.30.1.30 255.255.255.0
duplex auto
speed auto
media-type rj45
interface GigabitEthernet0/1
no ip address
shutdown
duplex auto
speed auto
media-type rj45
interface Serial1/0:15
no ip address
isdn incoming-voice voice
isdn T310 120000
isdn bind-l3 ccm-manager
isdn send-alerting
no cdp enable
interface Serial1/1:15
no ip address
no cdp enable
ip classless
ip route 0.0.0.0 0.0.0.0 10.30.1.100
no ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
control-plane
voice-port 1/0:15
voice-port 1/1:15
shutdown
mgcp
mgcp call-agent 10.30.1.1 2427 service-type mgcp version 0.1
mgcp dtmf-relay voip codec all mode out-of-band
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
mgcp package-capability rtp-package
no mgcp package-capability res-package
mgcp package-capability sst-package
no mgcp package-capability fxr-package
mgcp package-capability pre-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp fax t38 inhibit
mgcp rtp payload-type g726r16 static
mgcp profile default
dial-peer cor custom
CC_GW_1#
Where i was wrong???
Thanks.
Solved! Go to Solution.
01-12-2011 04:27 AM
No, MGCP only knows it's and endpoint with X amount of channels but you don't have control over which channel is used.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
01-11-2011 09:49 PM
I've solved problem with outgoing calls.
The issue was with "Top down" and "Bottom up" settings.
Please,can anyone explain me how to manage PRI channels for strict outgoing calls control?
Thanks.
01-12-2011 04:13 AM
You would need to configure regions and locations to limit the amount of calls a pool of devices can make to the GW.
java
01-12-2011 04:23 AM
Thanks for your reply.
I'll try this solution.
But,is there way to pair exact number with exact timeslot?
At the moment i'm using only translation patterns for in/out calls.
How i understand,it cann't be real solution for this issue.
01-12-2011 04:27 AM
java
01-12-2011 04:35 AM
Thanks.
And the last question please.
How i can make some directory without any third party soft and servers integration with?
For example:
All phone users able to search global "phone book" and make a simple search in it for names or DNs.
Thanks.
01-12-2011 04:38 AM
CUCM already has the global directory which is populated by either using the embedded Informix DB or synching with LDAP.
If you mean you want another directory or different capabilites from the one provided there is no way to do this without custom development and another server to host it.
java
01-12-2011 04:47 AM
Sorry,but i wasn't able find some info about it.
What i need is,to make some directory for users,if i have only CCM 5.1 and no LDAP or another adapters.
Thanks.
01-17-2011 04:23 AM
I've solved problem.
I only had to add users to the Standart End User group.
After that,corporate directory appeared in menu.
Javalenc,thanks a lot for your quick replies.
