01-24-2011 01:33 AM - edited 03-16-2019 03:02 AM
Hello
I have a CM 7.1.5 and some 7970 and 7945
When I click a Corporate Directory and search a user it appears only the name and number.
It is possible when I sync with AD by LDAP to appear the e-mail address, his manager and so on....?
It would be great to se all this stuf
it is a way how i can do this?
Cheers
Dragos
01-24-2011 07:02 AM
The corporate directory we provide only shows limited info.
If you want to provide more information the only way is to create your own custom directory script to do so.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
01-24-2011 07:08 AM
Thanks For your answer
Can you provide me a link with the steps in creating your own directory?
