CM Buisness Edition-6000
clark white
Level 2
Level 2
Dear,
UCS C220 M3 is supported for CM Business Edition 6000 but still i get the attached error, any hints.
Correct, yes, assuming you're running ESXi 5, those are the OVAs
java
if this helps, please rate
6 Replies 6
Jaime Valencia
Yes, if you were expecting a BE option, that won't happen. And that's not an error you're posting, that just the options you get during the wizard.
The actual co-res option during the install wizard only showed for 5K.
On 6K, you install each product as if it was a standalone product install, you just use the 6K OVA for each one.
Just as you need to deploy an OVA for each product you'll use in your 6K server.
java
www.cisco.com/go/pdihelpdesk
java
Dear Jaime,
Thanks for your reply,
What i know abt the BE is CUCM and CUC is combined in one application.
As per your reply what i understand is i have to install each product standalone, i.e CUCM and Cisco unity Connection,
when i want to install the CUCM i have to deploy CUCM 6K OVA (cucm_9.1_vmv8_v1.6)
and for unity connection as you say use the same OVA but  the option is not highlighting how i will install as a standalone with same 6K ova.
pleae correct me if my understanding is wrong.
I never said to use the same OVA, you need to use the right OVA for each product.
Just as there are OVAs for CUCM, there are for CUC, CUPS/IM&P, etc
Download and use the OVA for each product, then install each one, integrate them, and configure them.
java
Thanks Jaime,
so the conclusion is :
IN CM BE 6000 CUCM and CUC are not combined they have to be be installed standalone by their specific OVA's
Is it the below correct OVA for both products, (CUCM,CUC)
CUC_9.1_vmv8_v1.5.ova
cucm_9.1_vmv8_v1.6.ova
java
Thanks Jaime,
,Can you route me to the link.
where are these info present on cisco website that CM BE 6000 doesnt combined CUCM and CUC together.
