how to edit lines out of running-config
Mike Shoop
I erroneously entered the wrong file name for startup; so, I need to edit/delete some lines out of the startup-config file.
I think the following section of my startup-config...
boot-start-marker
boot system flash c2800nm-spservicesk9-mz.124-24.T2.bin
boot system flash
boot system flash:
boot system flash c2800nm-spservicesk9-mz.124.24.15.xz1.bin
boot-end-marker
"NEEDS TO BE AS FOLLOWS"
boot-start-marker
boot system flashc2800nm-spservicesk9-mz.124.24.15.xz1.bin
boot-end-marker
Chris Deren
Enter "no" in front of it, i.e.
no  boot system flash c2800nm-spservicesk9-mz.124-24.T2.bin
HTH,
Chris
Chris Deren
HTH,
Chris
Thank you Chris. I actually knew about the 'no' command but mistakenly thought it was exclusively for turning services off vs. editing script. thanks again for the quick reply and the good information. very grateful!
