CMC with CTI ports
Nicolas Mansour
Hi there,
I have the following setup where someone calls in to the auto attendant dials a specific code and then enters the number of an OffNet number. This works fine but for billing purposes if I try to add CMC to the route pattern, the calls are disconnected automatically.
I enabled the offnet-to-offnet transfer but that didn't work
Any clues?
Thanks in advance,
Nick
wong34539
Level 6
Level 6
When you have a CMC and FAC enabled on a route pattern, you have to enter FAC first, before entering CMC code.
