CME 10, FXS Ports call transfer
aheredia05
hello everyone,
i am tryin to enable the call transfer feature on my cme, i do not know what i am doing wrong.
i enabled the sccp and stcapp.
i have one 2901. the config file is attached.
Regards.
sorry for my english.
2 Accepted Solutions
Nadeem Ahmed
Is it working or not? what happened  when you transfering any call by pressing the hookflash button.
http://www.cisco.com/c/en/us/td/docs/ios/voice/fxs/configuration/guide/15_1/fxs_15_1_cg_book/fxssccpsplmft.html
Convert FXS to SCCP endpoint then try
Here is the basic configuration:
sccp local gi0/0.10
sccp ccm a.b.c.d identifier 1 (where a.b.c.d is CME's IP address)
sccp
sccp ccm group 1
bind int gi0/0.10
associate ccm 1 priority 1
stcapp ccm-group 1
stcapp
dial-peer voice 6080 pots
service stcapp
port 0/1/2
ephone-dn XX
number XXXX
ephone 15
mac-address AAAA.BBBB.CCCC (see below about how to find the MAC)
type anl
button 1:15
Br,
Nadeem
Br, Nadeem Please rate all useful post.
To find the MAC address, run "show stcapp device summary"
9 Replies 9
Nadeem Ahmed
sccp local gi0/0.10
sccp
sccp ccm group 1
bind int gi0/0.10
stcapp ccm-group 1
stcapp
service stcapp
port 0/1/2
ephone-dn XX
number XXXX
ephone 15
type anl
button 1:15
Br,
Nadeem
hello Nadeem,
1caller->2analog->3transfer
it is half working, i receive a call on my analog from, press flash button, have dialtone, but the call hangs up for the caller. and if it does not hang up, the call is not transfered.
mac-address AAAA.BBBB.CCCC //which mac address is this?, i have only one cme, sorry for this stupid question
regards.
i finally could register the analog phone,
thanks for your help.
Glad issue is resolved.
Br,
nadeem
my setup like this put the call transfer not working. I realized when I do Hookflash it displays dial tone, however when drive another extension gives busy signal. I am suspicious that can be version of IOS. Below is my setup
---runing config
stcapp ccm-group 1
stcapp
stcapp feature access-code
stcapp supplementary-services
 port 0/0/0
  fallback-dn 2000
 port 0/0/1
  fallback-dn 2001
 port 0/0/2
  fallback-dn 2002
 port 0/0/3
  fallback-dn 2003
stcapp call-control mode feature
voice-port 0/0/0
 no non-linear
 cptone BR
 timeouts ringing infinity
 description carol
 caller-id enable
voice-port 0/0/1
 no non-linear
 cptone BR
 description ricardo
 caller-id enable
voice-port 0/0/2
 no non-linear
 cptone BR
 description weverton
 caller-id enable
voice-port 0/0/3
 no non-linear
 cptone BR
 description jose
 caller-id enable
voice-port 0/3/0
voice-port 0/3/1
 supervisory disconnect dualtone mid-call
 cptone BR
 timeouts call-disconnect 5
 connection plar 3029XXXX
voice-port 0/3/2
voice-port 0/3/3
sccp local FastEthernet0/1
sccp ccm 192.168.1.1 identifier 1 version 7.0
sccp
sccp ccm group 1
 bind interface FastEthernet0/1
dial-peer voice 195 pots
 incoming called-number 0673029XXXX
dial-peer voice 220 pots
 destination-pattern 3029XXXX
 port 0/0/0
dial-peer voice 225 pots
 destination-pattern .T
 port 0/3/1
dial-peer voice 200 pots
 description carol
 destination-pattern 2000
 port 0/0/0
dial-peer voice 205 pots
 description ricardo
 destination-pattern 2001
 port 0/0/1
dial-peer voice 210 pots
 destination-pattern 2002
 port 0/0/2
dial-peer voice 215 pots
 description jose
 destination-pattern 2003
 port 0/0/3
dial-peer voice 100 pots
 service stcapp
 port 0/0/0
dial-peer voice 101 pots
 service stcapp
 port 0/0/1
dial-peer voice 102 pots
 service stcapp
 port 0/0/2
dial-peer voice 103 pots
 service stcapp
 port 0/0/3
telephony-service
 max-ephones 10
 max-dn 10
 ip source-address 192.168.1.1 port 2000
 timeouts transfer-recall 30
 max-conferences 8 gain -6
 call-forward pattern .T
 transfer-system full-consult
 transfer-pattern .T
 fac standard
ephone-dn  1
 number 2000
 transfer-mode consult
ephone-dn  2
 number 2001
ephone-dn  3
 number 2002
ephone-dn  4
 number 2003
ephone  1
 device-security-mode none
 mac-address 040E.7ED2.1000
 max-calls-per-button 2
 type anl
ephone  2
 mac-address 040E.7ED2.1001
 type anl
ephone  3
 mac-address 040E.7ED2.1002
 type anl
ephone  4
 mac-address 040E.7ED2.1003
 type anl
-------------end running-config
hercules#show stcapp feature code
    malicious call ID (MCID) ***
    prefix **
    call forward all **1
    call forward cancel **2
    pickup local group **3
    pickup different group **4
    meetme-conference **5
    pickup direct **6
    forward-to-voicemail **7
    cancel call waiting **8
  stcapp feature speed-dial disabled
  stcapp call-control mode is feature mode
    #1 -- hangup last active call
    #2 -- transfer
    #3 -- conference
    #4 -- drop last conferee
    #5 -- toggle between two calls
hercules#
hercules#show stcapp device summary
Total Devices:           4
Total Calls in Progress: 0
Total Call Legs in Use:  0
Port       Device          Device   Call          Dev     Directory   Dev
Identifier Name            State    State         Type    Number      Cntl
0/0/0      AN4040E7ED21000 IS       IDLE          ALG                 CME
0/0/1      AN4040E7ED21001 IS       IDLE          ALG                 CME
0/0/2      AN4040E7ED21002 IS       IDLE          ALG                 CME
0/0/3      AN4040E7ED21003 IS       IDLE          ALG                 CME
hercules#
show version
Cisco IOS Software, 2800 Software (C2800NM-ADVIPSERVICESK9-M), Version 15.1(3)T1, RELEASE SOFTWARE (fc2)
show telephony-service
CONFIG (Version=8.5)
Version 8.5
Max phoneload sccp version 17
Max dspfarm sccp version 18
Cisco Unified Communications Manager Express
Can you please collect below debugs while making a test call (Transfer)
Debug vpm signal
debug voice vtsp all
debug sccp all
Ramneeka
Hi ramneeka
thanks for response. follow my output debug
hercules#
hercules#
*Aug 19 14:09:43.046: htsp_process_event: [0/0/0, FXSLS_WAIT_OFFHOOK, E_DSP_SIG_1100]fxsls_waitoff_offhook
*Aug 19 14:09:43.050: [0/0/0] set signal state = 0x4 timestamp = 0
*Aug 19 14:09:43.050: [0/0/0] set signal state = 0x6 timestamp = 200
*Aug 19 14:09:43.050: htsp_timer2 - 200 msec
*Aug 19 14:09:43.250: htsp_process_event: [0/0/0, FXSLS_WAIT_OFFHOOK, E_HTSP_EVENT_TIMER2]fxsls_offhook_dial htsp_dial
*Aug 19 14:09:43.250: htsp_process_event: [0/0/0, FXSLS_WAIT_OFFHOOK, E_DSP_DIALING_DONE]fxsls_waitoff_dialdone
*Aug 19 14:09:43.250: //856/C121396A8FF2/VTSP:(0/0/0):-1:1:2/vtsp_process_event:
   [state:S_SETUP_REQ_PROC, event:E_TSP_CONNECT]
*Aug 19 14:09:43.250: //856/C121396A8FF2/VTSP:(0/0/0):-1:1:2/act_setup_pend_connect:
   Progress Indication=2
*Aug 19 14:09:43.250: //856/C121396A8FF2/VTSP:(0/0/0):-1:1:2/vtsp_ring_noan_timer_stop:
   Timer Stop Time=8183079
*Aug 19 14:09:43.254: //855/C121396A8FF2/VTSP:(0/3/1):-1:1:1/vtsp_process_event:
   [state:S_PROCEEDING, event:E_CC_CONNECT]
*Aug 19 14:09:43.254: //855/C121396A8FF2/VTSP:(0/3/1):-1:1:1/act_connect:
*Aug 19 14:09:43.254: //855/C121396A8FF2/VTSP:(0/3/1):-1:1:1/vtsp_timer_stop:
   Timer Stop Time=8183080
*Aug 19 14:09:43.254: //855/C121396A8FF2/VTSP:(0/3/1):-1:1:1/vtsp_ring_noan_timer_stop:
*Aug 19 14:09:43.258: htsp_process_event: [0/3/1, FXOLS_PROCEED_RVS_BT, E_HTSP_CONNECT]fxols_offhook_connect
*Aug 19 14:09:43.258: htsp_timer_stop
*Aug 19 14:09:53.750: htsp_process_event: [0/0/0, FXSLS_CONNECT, E_DSP_SIG_0100]fxsls_offhook_onhook, HF duration Max=1000, HF duration Min=150
*Aug 19 14:09:53.750: htsp_timer - 1000 msec
*Aug 19 14:09:54.046: htsp_process_event: [0/0/0, FXSLS_CONNECT, E_DSP_SIG_1100]fxsls_offhook_offhookhtsp_hook_flash_ind
*Aug 19 14:09:54.050: htsp_timer_stop
*Aug 19 14:09:54.050: //856/C121396A8FF2/VTSP:(0/0/0):-1:1:2/vtsp_process_event:
   [state:S_CONNECT, event:E_TSP_CALL_FEATURE_IND]
*Aug 19 14:09:54.050: //856/C121396A8FF2/VTSP:(0/0/0):-1:1:2/act_call_feature_ind:
   Feature Type=5
*Aug 19 14:09:54.050: //855/C121396A8FF2/VTSP:(0/3/1):-1:1:1/vtsp_process_event:
   [state:S_CONNECT, event:E_CC_FEATURE]
*Aug 19 14:09:54.050: //855/C121396A8FF2/VTSP:(0/3/1):-1:1:1/act_call_feature:
   Feature Type=5htsp_call_feature:feature 5
*Aug 19 14:09:54.050: htsp_process_event: [0/3/1, FXOLS_CONNECT, E_HTSP_HOOKFLASH]fxols_hookflash, interval=400
*Aug 19 14:09:54.054: [0/3/1] set signal state = 0x4 timestamp = 0
*Aug 19 14:09:54.054: [0/3/1] set signal state = 0xC timestamp = 400
*Aug 19 14:09:54.330: htsp_process_event: [0/3/1, FXOLS_CONNECT, E_DSP_SIG_0110]fxols_rvs_battery
*Aug 19 14:09:54.330: htsp_timer_stop2
*Aug 19 14:09:54.730: htsp_process_event: [0/3/1, FXOLS_CONNECT, E_DSP_SIG_0110]fxols_rvs_battery
*Aug 19 14:09:54.730: htsp_timer_stop2
*Aug 19 14:10:09.450: sccpapp_process_timer_events: appl_type 4, experied_timer 3, xlated_eve 11, state 6
*Aug 19 14:10:09.450: sccp_handle_keep_alive_timeout: Handle keepalive timeout for appl_type 4, state 6
*Aug 19 14:10:09.450: sccp_send_keep_alive_msg_v1: send keepalive id 0, len 4
*Aug 19 14:10:09.450: SCCP(AN4040E7ED21000)send KeepAliveMessage to ccm identifier 1
*Aug 19 14:10:09.450: sccp_transmit_msg: sending on socket 0
*Aug 19 14:10:09.450: sccp_appl_service_start_timer: Start timer type 3 with time_out 30000ms
*Aug 19 14:10:09.462: sccpapp_process_socket_events: appl_type 4, soc_fd 0, soc 0, swb_soc -1
*Aug 19 14:10:09.462: sccpapp_process_socket_events: TCP_SOCKET_READ: appl_type 4, eve 4, state 6
*Aug 19 14:10:09.462: sccp_get_control_message: bytes_to_read 8, bytes_read 8, appl_total_bytes 8, appl_bytes_read 8, soc_read_mode 0, soc 0
*Aug 19 14:10:09.462: sccp_get_control_message: bytes_to_read 4, bytes_read 4, appl_total_bytes 4, appl_bytes_read 4, soc_read_mode 1, soc 0
*Aug 19 14:10:09.462: sccp_get_control_message: sccp cntl msg rcvd, prof_id 0, appl_type 4, msg_len 4
*Aug 19 14:10:09.462: sccp_parse_control_msg: msg_ptr 4E0A8D5C, msg_len 4, msg_id 256
*Aug 19 14:10:09.462: sccp_parse_control_msg: glob_ccm->version 9
*Aug 19 14:10:09.462: SCCP(AN4040E7ED21000)rcvd KeepAliveAckMessage from ccm identifier 1
*Aug 19 14:10:09.466: sccpapp_process_timer_events: appl_type 4, experied_timer 3, xlated_eve 11, state 6
*Aug 19 14:10:09.466: sccp_handle_keep_alive_timeout: Handle keepalive timeout for appl_type 4, state 6
*Aug 19 14:10:09.466: sccp_send_keep_alive_msg_v1: send keepalive id 0, len 4
*Aug 19 14:10:09.466: SCCP(AN4040E7ED21001)send KeepAliveMessage to ccm identifier 1
*Aug 19 14:10:09.470: sccp_transmit_msg: sending on socket 1
*Aug 19 14:10:09.470: sccp_appl_service_start_timer: Start timer type 3 with time_out 30000ms
*Aug 19 14:10:09.478: sccpapp_process_socket_events: appl_type 4, soc_fd 1, soc 1, swb_soc -1
*Aug 19 14:10:09.478: sccpapp_process_socket_events: TCP_SOCKET_READ: appl_type 4, eve 4, state 6
*Aug 19 14:10:09.478: sccp_get_control_message: bytes_to_read 8, bytes_read 8, appl_total_bytes 8, appl_bytes_read 8, soc_read_mode 0, soc 1
*Aug 19 14:10:09.478: sccp_get_control_message: bytes_to_read 4, bytes_read 4, appl_total_bytes 4, appl_bytes_read 4, soc_read_mode 1, soc 1
*Aug 19 14:10:09.478: sccp_get_control_message: sccp cntl msg rcvd, prof_id 0, appl_type 4, msg_len 4
*Aug 19 14:10:09.478: sccp_parse_control_msg: msg_ptr 4C70BD28, msg_len 4, msg_id 256
*Aug 19 14:10:09.478: sccp_parse_control_msg: glob_ccm->version 9
*Aug 19 14:10:09.478: SCCP(AN4040E7ED21001)rcvd KeepAliveAckMessage from ccm identifier 1
*Aug 19 14:10:09.482: sccpapp_process_timer_events: appl_type 4, experied_timer 3, xlated_eve 11, state 6
*Aug 19 14:10:09.482: sccp_handle_keep_alive_timeout: Handle keepalive timeout for appl_type 4, state 6
*Aug 19 14:10:09.482: sccp_send_keep_alive_msg_v1: send keepalive id 0, len 4
*Aug 19 14:10:09.486: SCCP(AN4040E7ED21002)send KeepAliveMessage to ccm identifier 1
*Aug 19 14:10:09.486: sccp_transmit_msg: sending on socket 2
*Aug 19 14:10:09.486: sccp_appl_service_start_timer: Start timer type 3 with time_out 30000ms
*Aug 19 14:10:09.494: sccpapp_process_socket_events: appl_type 4, soc_fd 2, soc 2, swb_soc -1
*Aug 19 14:10:09.494: sccpapp_process_socket_events: TCP_SOCKET_READ: appl_type 4, eve 4, state 6
*Aug 19 14:10:09.494: sccp_get_control_message: bytes_to_read 8, bytes_read 8, appl_total_bytes 8, appl_bytes_read 8, soc_read_mode 0, soc 2
*Aug 19 14:10:09.494: sccp_get_control_message: bytes_to_read 4, bytes_read 4, appl_total_bytes 4, appl_bytes_read 4, soc_read_mode 1, soc 2
*Aug 19 14:10:09.494: sccp_get_control_message: sccp cntl msg rcvd, prof_id 0, appl_type 4, msg_len 4
*Aug 19 14:10:09.494: sccp_parse_control_msg: msg_ptr 4A7F8B90, msg_len 4, msg_id 256
*Aug 19 14:10:09.494: sccp_parse_control_msg: glob_ccm->version 9
*Aug 19 14:10:09.494: SCCP(AN4040E7ED21002)rcvd KeepAliveAckMessage from ccm identifier 1
*Aug 19 14:10:09.494: sccpapp_process_timer_events: appl_type 4, experied_timer 3, xlated_eve 11, state 6
*Aug 19 14:10:09.494: sccp_handle_keep_alive_timeout: Handle keepalive timeout for appl_type 4, state 6
*Aug 19 14:10:09.494: sccp_send_keep_alive_msg_v1: send keepalive id 0, len 4
*Aug 19 14:10:09.498: SCCP(AN4040E7ED21003)send KeepAliveMessage to ccm identifier 1
*Aug 19 14:10:09.498: sccp_transmit_msg: sending on socket 3
*Aug 19 14:10:09.498: sccp_appl_service_start_timer: Start timer type 3 with time_out 30000ms
*Aug 19 14:10:09.506: sccpapp_process_socket_events: appl_type 4, soc_fd 3, soc 3, swb_soc -1
*Aug 19 14:10:09.506: sccpapp_process_socket_events: TCP_SOCKET_READ: appl_type 4, eve 4, state 6
*Aug 19 14:10:09.506: sccp_get_control_message: bytes_to_read 8, bytes_read 8, appl_total_bytes 8, appl_bytes_read 8, soc_read_mode 0, soc 3
*Aug 19 14:10:09.506: sccp_get_control_message: bytes_to_read 4, bytes_read 4, appl_total_bytes 4, appl_bytes_read 4, soc_read_mode 1, soc 3
*Aug 19 14:10:09.510: sccp_get_control_message: sccp cntl msg rcvd, prof_id 0, appl_type 4, msg_len 4
*Aug 19 14:10:09.510: sccp_parse_control_msg: msg_ptr 489F5D08, msg_len 4, msg_id 256
*Aug 19 14:10:09.510: sccp_parse_control_msg: glob_ccm->version 9
*Aug 19 14:10:09.510: SCCP(AN4040E7ED21003)rcvd KeepAliveAckMessage from ccm identifier 1
*Aug 19 14:10:10.566: htsp_process_event: [0/0/0, FXSLS_CONNECT, E_DSP_SIG_0100]fxsls_offhook_onhook, HF duration Max=1000, HF duration Min=150
*Aug 19 14:10:10.566: htsp_timer - 1000 msec
*Aug 19 14:10:10.870: htsp_process_event: [0/0/0, FXSLS_CONNECT, E_DSP_SIG_1100]fxsls_offhook_offhookhtsp_hook_flash_ind
*Aug 19 14:10:10.870: htsp_timer_stop
*Aug 19 14:10:10.870: //856/C121396A8FF2/VTSP:(0/0/0):-1:1:2/vtsp_process_event:
*Aug 19 14:10:10.870: //856/C121396A8FF2/VTSP:(0/0/0):-1:1:2/act_call_feature_ind:
   Feature Type=5
*Aug 19 14:10:10.874: //855/C121396A8FF2/VTSP:(0/3/1):-1:1:1/vtsp_process_event:
*Aug 19 14:10:10.874: //855/C121396A8FF2/VTSP:(0/3/1):-1:1:1/act_call_feature:
*Aug 19 14:10:10.874: htsp_process_event: [0/3/1, FXOLS_CONNECT, E_HTSP_HOOKFLASH]fxols_hookflash, interval=400
*Aug 19 14:10:10.874: [0/3/1] set signal state = 0x4 timestamp = 0
*Aug 19 14:10:10.874: [0/3/1] set signal state = 0xC timestamp = 400
*Aug 19 14:10:11.150: htsp_process_event: [0/3/1, FXOLS_CONNECT, E_DSP_SIG_0110]fxols_rvs_battery
*Aug 19 14:10:11.150: htsp_timer_stop2
*Aug 19 14:10:11.550: htsp_process_event: [0/3/1, FXOLS_CONNECT, E_DSP_SIG_0110]fxols_rvs_battery
*Aug 19 14:10:11.550: htsp_timer_stop2
*Aug 19 14:10:21.750: htsp_process_event: [0/0/0, FXSLS_CONNECT, E_DSP_SIG_0100]fxsls_offhook_onhook, HF duration Max=1000, HF duration Min=150
*Aug 19 14:10:21.750: htsp_timer - 1000 msec
*Aug 19 14:10:22.750: htsp_process_event: [0/0/0, FXSLS_CONNECT, E_HTSP_EVENT_TIMER]fxsls_connect_wait_release_req
*Aug 19 14:10:22.750: htsp_timer_stop
*Aug 19 14:10:22.750: //856/C121396A8FF2/VTSP:(0/0/0):-1:1:2/vtsp_process_event:
   [state:S_CONNECT, event:E_TSP_DISCONNECT_IND]
*Aug 19 14:10:22.750: //856/C121396A8FF2/VTSP:(0/0/0):-1:1:2/act_generate_disc:
   Cause Value=16
*Aug 19 14:10:22.750: //856/C121396A8FF2/VTSP:(0/0/0):-1:1:2/vtsp_timer_stop:
   Timer Stop Time=8187029
*Aug 19 14:10:22.750: //856/C121396A8FF2/VTSP:(0/0/0):-1:1:2/vtsp_ring_noan_timer_stop:
*Aug 19 14:10:22.750: //856/C121396A8FF2/VTSP:(0/0/0):-1:1:2/vtsp_set_release_source:
   Release Direction=PSTN, Release Source=Called Party-PSTN
*Aug 19 14:10:22.750: //856/C121396A8FF2/VTSP:(0/0/0):-1:1:2/vtsp_cc_call_disconnected:
   Cause Value=16
*Aug 19 14:10:22.754: //856/C121396A8FF2/VTSP:(0/0/0):-1:1:2/vtsp_timer:
   Timer Start Time=8187030, Timer Value=15000(ms)
*Aug 19 14:10:22.754: //856/C121396A8FF2/VTSP:(0/0/0):-1:1:2/act_generate_disc:
   Return Code=0
*Aug 19 14:10:22.754: //855/C121396A8FF2/VTSP:(0/3/1):-1:1:1/vtsp_dsm_bridge_status_cb:
*Aug 19 14:10:22.754: //856/C121396A8FF2/VTSP:(0/0/0):-1:1:2/vtsp_dsm_bridge_status_cb:
*Aug 19 14:10:22.758: //855/C121396A8FF2/VTSP:(0/3/1):-1:1:1/vtsp_process_event:
   [state:S_CONNECT, event:E_CC_DISCONNECT]
*Aug 19 14:10:22.758: //855/C121396A8FF2/VTSP:(0/3/1):-1:1:1/act_disconnect:
   Cause Value=16
*Aug 19 14:10:22.758: //855/C121396A8FF2/VTSP:(0/3/1):-1:1:1/vtsp_ring_noan_timer_stop:
   Timer Stop Time=8187030
*Aug 19 14:10:22.758: //855/C121396A8FF2/VTSP:(0/3/1):-1:1:1/vtsp_timer:
   Timer Start Time=8187030, Timer Value=5000(ms)
   Waiting For Disconnect Confirmation Timeout=5(s)
*Aug 19 14:10:22.762: //856/C121396A8FF2/VTSP:(0/0/0):-1:1:2/vtsp_process_event:
*Aug 19 14:10:22.762: //856/C121396A8FF2/VTSP:(0/0/0):-1:1:2/act_disconnect:
   Cause Value=16, Previous Cause Value=16
*Aug 19 14:10:22.762: //856/C121396A8FF2/VTSP:(0/0/0):-1:1:2/vtsp_ring_noan_timer_stop:
*Aug 19 14:10:22.762: //856/C121396A8FF2/VTSP:(0/0/0):-1:1:2/vtsp_timer:
   Timer Start Time=8187030, Timer Value=60000(ms)
   Waiting For Disconnect Confirmation Timeout=60(s)
*Aug 19 14:10:22.762: htsp_process_event: [0/3/1, FXOLS_CONNECT, E_HTSP_RELEASE_REQ]fxols_offhook_release
*Aug 19 14:10:22.762: htsp_timer_stop
*Aug 19 14:10:22.762: htsp_timer_stop2
*Aug 19 14:10:22.762: htsp_timer_stop3
*Aug 19 14:10:22.762: [0/3/1] set signal state = 0x4 timestamp = 0
*Aug 19 14:10:22.762: htsp_timer - 2000 msec
*Aug 19 14:10:22.762: //855/C121396A8FF2/VTSP:(0/3/1):-1:1:1/vtsp_process_event:
   [state:S_WAIT_RELEASE, event:E_TSP_DISCONNECT_CONF]
*Aug 19 14:10:22.762: //855/C121396A8FF2/VTSP:(0/3/1):-1:1:1/act_wrelease_release:
*Aug 19 14:10:22.762: //855/C121396A8FF2/VTSP:(0/3/1):-1:1:1/vtsp_play_busy_timer_stop:
*Aug 19 14:10:22.762: //855/C121396A8FF2/VTSP:(0/3/1):-1:1:1/vtsp_timer_stop:
*Aug 19 14:10:22.762: //855/C121396A8FF2/VTSP:(0/3/1):-1:1:1/vtsp_do_call_history:
*Aug 19 14:10:22.766: //855/C121396A8FF2/VTSP:(0/3/1):-1:1:1/vtsp_do_call_history:
   Coder Rate=-1
*Aug 19 14:10:22.766: //855/C121396A8FF2/VTSP:(0/3/1):-1:1:1/vtsp_is_valid_dsm_handle:
   DMGR=0x4A7FCCF8, VTSP CDB=0x4C54E248
*Aug 19 14:10:22.766: htsp_process_event: [0/0/0, FXSLS_WAIT_RELEASE_REQ, E_HTSP_RELEASE_REQ]fxsls_waitrls_req_rls
*Aug 19 14:10:22.766: [0/0/0] set signal state = 0x4 timestamp = 0
*Aug 19 14:10:22.770: //856/C121396A8FF2/VTSP:(0/0/0):-1:1:2/vtsp_process_event:
*Aug 19 14:10:22.770: //856/C121396A8FF2/VTSP:(0/0/0):-1:1:2/act_wrelease_release:
*Aug 19 14:10:22.770: //856/C121396A8FF2/VTSP:(0/0/0):-1:1:2/vtsp_play_busy_timer_stop:
   Timer Stop Time=8187031
*Aug 19 14:10:22.770: //856/C121396A8FF2/VTSP:(0/0/0):-1:1:2/vtsp_timer_stop:
*Aug 19 14:10:22.770: //856/C121396A8FF2/VTSP:(0/0/0):-1:1:2/vtsp_do_call_history:
   Coder Rate=-1
*Aug 19 14:10:22.774: //856/C121396A8FF2/VTSP:(0/0/0):-1:1:2/vtsp_is_valid_dsm_handle:
   DMGR=0x4A7F21A4, VTSP CDB=0x4C54DC98
*Aug 19 14:10:22.774: htsp_process_event: [0/0/0, FXSLS_ONHOOK, E_DSP_SIG_0100]fxsls_onhook_onhook
*Aug 19 14:10:22.778: //855/C121396A8FF2/VTSP:(0/3/1):-1:-1:-1/vtsp_dsm_closed_cb:
*Aug 19 14:10:22.778: //856/C121396A8FF2/VTSP:(0/0/0):-1:-1:-1/vtsp_dsm_closed_cb:
*Aug 19 14:10:22.778: //855/C121396A8FF2/VTSP:(0/3/1):-1:-1:-1/vtsp_process_event:
   [state:S_CLOSE_DSPRM, event:E_VTSP_DSM_CLOSE_COMPLETE]
*Aug 19 14:10:22.778: //855/C121396A8FF2/VTSP:(0/3/1):-1:-1:-1/act_terminate:
*Aug 19 14:10:22.778: //855/C121396A8FF2/VTSP:(0/3/1):-1:-1:-1/vtsp_timer_stop:
   Timer Stop Time=8187032
*Aug 19 14:10:22.782: //-1/C121396A8FF2/VTSP:(0/3/1):-1:-1:-1/vtsp_free_cdb:
   CDB=0x4C54E248
*Aug 19 14:10:22.782: //856/C121396A8FF2/VTSP:(0/0/0):-1:-1:-1/vtsp_process_event:
*Aug 19 14:10:22.782: //856/C121396A8FF2/VTSP:(0/0/0):-1:-1:-1/act_terminate:
*Aug 19 14:10:22.782: //856/C121396A8FF2/VTSP:(0/0/0):-1:-1:-1/vtsp_timer_stop:
*Aug 19 14:10:22.782: //-1/C121396A8FF2/VTSP:(0/0/0):-1:-1:-1/vtsp_free_cdb:
   CDB=0x4C54DC98
*Aug 19 14:10:23.034: htsp_process_event: [0/3/1, FXOLS_GUARD_OUT, E_DSP_SIG_0110]
*Aug 19 14:10:24.762: htsp_process_event: [0/3/1, FXOLS_GUARD_OUT, E_HTSP_EVENT_TIMER]fxols_guard_out_timeout
*Aug 19 14:10:24.782: htsp_process_event: [0/3/1, FXOLS_ONHOOK, E_DSP_SIG_0100]
Regards.
Hi all.
I solved the problem, it was my fault. I had a "connection plar" to the actual number and used a dial-peer to direct for FXS, there have set up the "connection plar" straight to the extension and the transfer worked. I'm sorry. Thank you very much for your help and good to the community.
