CME 11.5 File set
a.trueland1
Is the GUI for CME 11.5 included in the IOS or is it the file set download ?  The file set is 295mb!  Why so large ? 10.5 is .80.
AT
Jonathan Unger
Level 7
Level 7
Hi There,
The CME GUI is not included in the IOS. It is available in the file set download.
The reason that the 10.5 download is so much smaller, is because it only contains the GUI files (a couple HTML files and some images).
The 11.5 complete package contains much more (CME GUI Files, B-ACD Scripts, many different locale files, ring tones, MoH, etc...).
If you are interested in examining exactly what is in each archive you can download an application which can open .tar files. My personal favourite is 7-zip http://www.7-zip.org/download.html .
Hope this helps.
Hi , Do we need to install all the locale files in CME or specific language which we need...
