03-08-2018 01:17 AM - edited 03-17-2019 12:22 PM
I am using CME 11.5 and I registered sip 7811 phones to it and operating well without installing CME files so I want to know what are the benefits of CME files
Solved! Go to Solution.
03-08-2018 02:23 AM
the version of your CME depend of the IOS version of your router.
See the matrix here:
Then, the file CME11.5.tar can upgrade your CME version without upgrading your IOS.
With this file you've got access with phone template, music in hold file etc...
You only need to extract this files on your flash.
show telephony-service
show voice register global
two commands in order to see your CME version.
03-08-2018 04:58 AM
03-08-2018 02:23 AM
03-08-2018 03:28 AM
Thanks for that information I didn't know that before
I upgraded the ios to upgrade CME version
Then I don't need CME files for ordinary use of calls ?
03-08-2018 03:48 AM
You don't need that if U upgrade your IOS and if you've got the good CME version.
Best Regards.
Ben.
03-08-2018 04:58 AM
03-08-2018 05:13 AM
Yes, for sure the only way to use tar file cme11.5 is to install in your flash: what U need specificaly on this version.
But tthe way to upgrade from CME 8.6 to CME 11.5 is to upgrade the IOS router.
Then, U don't need anymore the tar file.
In term of being specific
here U find the documentation:
CME install is the "holy bible".
Best Regards
Ben
03-11-2018 06:05 AM
I can't understand your argue
can you both illustrate little a
Best Regards
Ben
bit?
03-11-2018 09:57 AM - edited 03-11-2018 09:58 AM
The only way to upgrade CME version is to upgrade you IOS router.
See the matrix between CME version and IOS.
Nevertheless, if you have the cme tar file with a version upper than your cme version....for example you have cme 9.0 due to your router IOS version....on the other hand you have the cme11.6 tar file....you can use files on this tar for your cme feature...music on hold, ringtones etc....but it's not an upgrade of your cme 9.0.
Best regards.
Ben
08-02-2023 09:09 PM
Thank you so much for the best information shared here. I would love to share it with my friends and help them with this information. Thanks again.
