05-22-2023 05:18 PM - last edited on 05-22-2023 08:31 PM by rupeshah
Config below, simple setup following guide from Cisco here
On how to auto-register SIP Based phones. We have a bunch of these 8841's we want to be able to auto register and test before we ship out into the field and have this spare router to do so. However, I must be missing something here because the phones won't register at all and I keep getting the below errors. Any idea on this one?
May 22 17:16:57.362 PDT: VOICE_REG_POOL: No entry for (AUTO-REG) found in contact table
May 22 17:16:57.366 PDT: VOICE_REG_POOL: No entry for (AUTO-REG) found in contact table
May 22 17:16:57.370 PDT: VOICE_REG_POOL: No entry for (AUTO-REG) found in contact table
May 22 17:16:57.378 PDT: VOICE_REG_POOL: No entry for (AUTO-REG) found in contact table
May 22 17:16:57.398 PDT: VOICE_REG_POOL: No entry for (AUTO-REG) found in contact table
May 22 17:16:57.398 PDT: voice_reg_get_reg_expires_timer: no voice register pool found
May 22 17:16:57.398 PDT: VOICE_REG_POOL: Register request for (AUTO-REG) from (172.30.10.3)
May 22 17:16:57.398 PDT: VOICE_REG_POOL: Auto Registration request from Name:xxx IP:172.30.10.3
May 22 17:16:57.398 PDT: VOICE_REG_POOL: Auto-register: DN tag not found
May 22 17:16:57.398 PDT: voice_reg_get_phone_index_from_contact: No contact list
May 22 17:16:57.402 PDT: VOICE_REG_POOL: No entry for (AUTO-REG) found in contact table
=========== configuration
Current configuration : 5158 bytes
version 15.6
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
hostname xxx
boot-start-marker
boot system flash:c2900-universalk9-mz.SPA.156-3.M5.bin
boot-end-marker
logging buffered 128000
no aaa new-model
clock timezone PST -8 0
clock summer-time PDT recurring
ip dhcp excluded-address 172.30.10.250 172.30.10.254
ip dhcp excluded-address 172.30.35.250 172.30.35.254
ip dhcp pool voice
network 172.30.10.0 255.255.255.0
default-router 172.30.10.254
dns-server 8.8.8.8
option 150 ip 172.30.10.254
ip cef
no ipv6 cef
voice-card 0
voice service voip
ip address trusted list
ipv4 0.0.0.0 0.0.0.0
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
sip
bind control source-interface GigabitEthernet0/0.200
bind media source-interface GigabitEthernet0/0.200
registrar server
midcall-signaling passthru media-change
voice register global
mode cme
create profile sync xxx
auto-register
password xxx
auto-assign 1 to 100
template 10
vxml logging-tag
license udi pid xxx sn xxx
hw-module pvdm 0/0
file privilege 0
redundancy
interface Embedded-Service-Engine0/0
no ip address
shutdown
description Uplink 3560-24 Port 23
no ip address
duplex auto
speed auto
interface GigabitEthernet0/0.10
description Management
encapsulation dot1Q 10
ip address 10.10.10.14 255.255.255.0
description Voice Network
encapsulation dot1Q 200
ip address 172.30.10.254 255.255.255.0
interface GigabitEthernet0/1
no ip address
duplex auto
speed auto
interface GigabitEthernet0/2
no ip address
duplex auto
speed auto
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip tftp source-interface GigabitEthernet0/0.200
ip dns server
ip route 0.0.0.0 0.0.0.0 10.10.10.1
ip ssh version 2
ip scp server enable
ipv6 ioam timestamp
snmp-server packetsize 1024
tftp-server flash1:SCCP45.9-4-2SR3-1S.loads
tftp-server flash1:term45.default.loads
tftp-server flash1:term65.default.loads
tftp-server flash1:cnu45.9-4-2ES26.sbn
tftp-server flash1:apps45.9-4-2ES26.sbn
tftp-server flash1:dsp45.9-4-2ES26.sbn
tftp-server flash1:jar45sccp.9-4-2ES26.sbn
tftp-server flash1:cvm45sccp.9-4-2ES26.sbn
tftp-server flash1:term11.default.loads
tftp-server flash1:term06.default.loads
tftp-server flash1:SCCP11.9-4-2SR3-1S.loads
tftp-server flash1:jar11sccp.9-4-2ES26.sbn
tftp-server flash1:dsp11.9-4-2ES26.sbn
tftp-server flash1:cvm11sccp.9-4-2ES26.sbn
tftp-server flash1:cnu11.9-4-2ES26.sbn
tftp-server flash1:apps11.9-4-2ES26.sbn
tftp-server flash:sb288xx.BE-01-026.sbn
tftp-server flash:sb2288xx.BE-01-013.sbn
tftp-server flash:sip88xx.12-5-1SR3-74.loads
tftp-server flash:ssb288xx.BE-01-007.sbn
tftp-server flash:vc488xx.12-5-1SR3-74.sbn
tftp-server flash:boot1288xx.BE-01-007.sbn
tftp-server flash:fbi88xx.BE-01-012.sbn
tftp-server flash:kern88xx.12-5-1SR3-74.sbn
tftp-server flash:kern288xx.12-5-1SR3-74.sbn
tftp-server flash:m0patch288xx.BE-01-001.sbn
tftp-server flash:rootfs288xx.12-5-1SR3-74.sbn
tftp-server flash:rootfs88xx.12-5-1SR3-74.sbn
control-plane
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
gateway
timer receive-rtp 1200
sip-ua
retry register 10
gatekeeper
shutdown
telephony-service
max-ephones 110
max-dn 400
ip source-address 172.30.10.254 port 2000
auto assign 1 to 100
max-conferences 8 gain -6
web admin system name xxx password xxx
transfer-system full-consult
create cnf-files version-stamp 7960 May 22 2023 17:01:17
Solved! Go to Solution.
05-22-2023 09:57 PM
I dont see the below configured under your voice register global.
max-dn
max-pool
05-22-2023 11:08 PM
Hello @netgn,
Where are your voice register dn and pool?
05-22-2023 09:57 PM
max-dn
max-pool
07-11-2023 10:19 AM
Sorry for delay in responding, yes this solved it thank you!!
07-11-2023 11:00 AM
Great news! Happy for you!
You're so welcome @netgn
05-22-2023 11:08 PM
Hello @netgn,
