cme 3945 router sip phone
dear all:
i got new project that contain cisco router 3045 cme 10.5 and all ip telephone support sip phone its voice register global .configuration
i have cisco ip phone 7821 = 120 phone and 8851 with expansion module.14
so now i configure everything and working fine i can call each extension and call outside .
i have some issue till now i did not find any solution and i need your help .
1- local directory when i press the button .................1- local directory then i find host not found
2- if i am receiving call from outside its showing in ip telephone unknown number
3- paging , intercom , conference  how to configure these features.?
4- cisco ip phone 8800 key Expansion module how to configure it ?
please i need help from any one
thanks
Jaime Valencia
1 Look at the config for directories in CME admin guide
2 Debug the call and see what you're getting from telco
3 Read the CME admin guide, all those features are covered in there
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucme/command/reference/cme_cr/cme_t1ht.html#wp3510247101
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucme/admin/configuration/guide/cmeadm/cmebasic.html#wp1043996
Example:
 type 7965 addon 1 7915-24
java
if this helps, please rate
