CME 8.1: Cannot associate hw conference adhoc
chingkiatlee
Hi all,
I am trying to configure the hardware conference for my customer in the CME 8.1 environment.
When i trying to associate the DN into the Cisco SCCP phone, it showed me "Cannot associate hw conference adhoc dn 140 to button 1"
But my sccp conference has registered and associated with CME server
Below is the configuration:
sccp local GigabitEthernet0/0
sccp ccm 192.168.1.254 identifier 1 version 7.0
sccp
sccp ccm group 1
bind interface GigabitEthernet0/0
associate ccm 1 priority 1
associate profile 100 register CME-CONF
dspfarm profile 100 conference
codec g711ulaw
codec g711alaw
maximum sessions 5
conference-join custom-cptone jointone
associate application SCCP
telephony-service
sdspfarm conference mute-on 1 mute-off 2
sdspfarm units 5
sdspfarm tag 1 CME-CONF
conference hardware
max-ephones 250
max-dn 288
ip source-address 192.168.1.254 port 2000
url services http:///voiceview/common/login.do
url authentication http:///voiceview/authentication/authenticate.do
cnf-file location flash:
cnf-file perphone
load 7914 S00105000100
load 7911 SCCP11.8-5-2S
load 7960-7940 P00307020400
time-zone 42
time-format 24
date-format dd-mm-yy
voicemail 200
max-conferences 8 gain -6
hunt-group logout HLog
dn-webedit
time-webedit
transfer-system full-consult
secondary-dialtone 9
create cnf-files version-stamp 7960 Jun 07 2013 19:38:41
ephone-dn  140  octo-line
number 720
label test
conference ad-hoc
no huntstop
show sccp
SCCP Admin State: UP
Gateway Local Interface: GigabitEthernet0/0
        IPv4 Address: 192.168.1.254
        Port Number: 2000
IP Precedence: 5
User Masked Codec list: None
Call Manager: 192.168.1.254, Port Number: 2000
                Priority: N/A, Version: 7.0, Identifier: 1
                Trustpoint: N/A
Conferencing Oper State: ACTIVE - Cause Code: NONE
Active Call Manager: 192.168.1.254, Port Number: 2000
TCP Link Status: CONNECTED, Profile Identifier: 100
Reported Max Streams: 40, Reported Max OOS Streams: 0
Supported Codec: g711ulaw, Maximum Packetization Period: 30
Supported Codec: g711alaw, Maximum Packetization Period: 30
Supported Codec: rfc2833 dtmf, Maximum Packetization Period: 30
Supported Codec: rfc2833 pass-thru, Maximum Packetization Period: 30
Supported Codec: inband-dtmf to rfc2833 conversion, Maximum Packetization Period: 30
TLS : ENABLED
Anyone have any idea?
6 Replies 6
paolo bevilacqua
Update IOS and check again.
Hi Paolo, update the CME or the Router IOS?
thanky you
updating CME means updating IOS.
kindly find the below link
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/requirements/guide/33matrix.htm
Anas
please don't forget to rate the helpful posts
Hi Paolo Bevilacqua & Anas Abu Eideh
I have figure the issue is not cause of IOS.
The is because i need to manually add in the DN for the conference purpose.
Below is the good article and explanation.
http://rsccievoice.wordpress.com/2012/06/25/conference-bridge/
thank you.
Is there any timeout config if any of the party (non initiator) call get disconnect and get disconnect from the hardware conference session?
thank you
karroplan
Hi!
Sorry for a bit later answer, but it may be helpfull for people facing same issue.
The point is in that DN with "conf ad-hoc" should not be tied to phone, but just left alone and there should be at least one such DN it config for conferencing to work. When someone creates conference CME uses these DN to do the bridging - it's just internal resourse and shoudn't be tied to phone.
Config is following:
! // this is fake DN for conferencing
ephone-dn  501  octo-line //octo-line for bridge up to 8 calls
 number 3599
 name Conf1
 conference ad-hoc
 preference 1
! // this one is real DN on phone
ephone-dn  7 octo
 number 3511
 label Mohhamed Abu Ibn Abdul
 name Mohhamed Abu Ibn Abdul
 corlist incoming unrestricted
ephone  7
 button  1:7 // <-- DN 7 here, at it has no "ad-hoc" option.
 restart
Of course, all other config has to be done:
1. voice-card X
  dspservices dspfarm
2. dspfarm profile for conferencing
3. sccp config to use dspfarm profile
