CME 8.6 and MOH
cigalahgroup
     I have CME 8.6 working on 2851 router but MOH is not working please check the below configuration and let me know if they are correct.
CME ROUTER 192.168.200.1 CONNECTED TO LAYER 3 SWITCH 3650 WITH 2 VLANS
SWITCH
VLAN 102 DATA
10.100.102.1
VLAN 103 VOICE
10.100.103.1
ROUTER CME
interface GigabitEthernet0/1
ip address 192.168.200.1 255.255.255.0
ip pim sparse-dense-mode
ip tcp adjust-mss 1300
load-interval 30
duplex auto speed
auto media-type rj45
Router#sh run | sec telephony-service
telephony-service
load 7961 SCCP41.8-3-3S.loads
load 7911 SCCP11.8-4-2S
max-ephones 10
max-dn 10
ip source-address 192.168.200.1 port 2000
system message C Establishment
date-format dd-mm-yy
max-conferences 12 gain -6
moh music-on-hold.au
multicast moh 239.1.1.1 port 16384 route 192.168.200.1 10.103.0.1
web admin system name admin password admin
dn-webedit
time-webedit
transfer-system full-consult
create cnf-files version-stamp Jan 01 2002 00:00:00
After waiting so much on the forums there was no help how ever I have figured out the problem reading it .
Layer 3 switch should have following commands
ip multi casting redistributed ( To enable Multi casting on the switch)
ip routing ( To enable the Routing)
Then go the the voice Vlan and give the below command
ip pim passive
EXAMPLE
ip routing
ip multicast-routing distributed
interface FastEthernet1/0/1
description ** router G0/0 **
no switchport
bandwidth 100000
ip address 172.21.101.17 255.255.255.248
speed 100
duplex full
interface Vlan211
description ** VOICE **
ip address 10.10.10.254 255.255.255.0
ip pim passive
Router side
telephony-service
ip source-address 10.11.10.254 port 2000
moh "flash:music-on-hold.au"
multicast moh 239.0.0.1 port 2000 route 10.11.10.254 172.21.101.22
interface Loopback0
description ** Loopback **
ip address 10.11.10.254 255.255.255.255
interface GigabitEthernet0/0
description ** switch F1/0/1 **
bandwidth 100000
ip address 172.21.101.22 255.255.255.248
cigalahgroup
With the Above configuration its works well form PSTN but locally its not working
ip pim passive
EXAMPLE
ip routing
no switchport
bandwidth 100000
speed 100
duplex full
interface Vlan211
ip pim passive
Router side
telephony-service
interface Loopback0
bandwidth 100000
