UCK9 Eval Period
Flo.Matalis
Hi Experts, just want to check with you below:
Technology Package License Information for Module:'c2900'
Technology Technology-package Technology-package
Current Type Next reboot
ipbase ipbasek9 Permanent ipbasek9
security securityk9 Permanent securityk9
uc uck9 EvalRightToUse uck9 <<<<<<<<<<<<<<<<<<<<<<<<<<<<<
data datak9 Permanent datak9
Index 3 Feature: uck9
Period left: 8 weeks 3 days
Period Used: 1 minute 28 seconds
License Type: EvalRightToUse <<<<<<<<<<<<<<<<<<<<<<<<<<<<<
License State: Active, In Use
License Count: Non-Counted
License Priority: Low
System image file is "flash0:c2900-universalk9-mz.SPA.151-2.T5.bin"
Have read from below the lists of IOS that is supported for RightToUse.For the case of my IOS, I am planning to enable the CME-SRST feature, but before that, I would like to know if my UCK9 license will become RightToUse? or features will be disabled after the evaluation?
Cisco IOS Software Releases Supported
The following Cisco IOS software releases support software activation on Cisco ISRs:
• Cisco 3900 series, 2900 series, and 1900 series ISRs running Cisco IOS Release 15.0(1)M.
– Cisco 3925E and Cisco 3945E ISR running Cisco IOS Release 15.1(1)T.
• Right to Use license is supported on Cisco IOS Release 15.0(1)M4, 15.1(1)T2, 15.1(2)T2, 15.1(3)T,
15.1(4)M1, or later.
• Cisco 800 series ISRs running Cisco IOS Release 12.4(15)XZ or later support either the
non-cryptographic image or the cryptographic image.
• Cisco 800 series ISRs running Cisco IOS Release images earlier than Cisco IOS Release
12.4(15)XZ do not support software activation.
• Cisco One Suite License is supported only on Cisco 3900 series, 2900 series, and 1900 series ISRs
running Cisco IOS Release 15.5(1)T.
https://www.cisco.com/c/en/us/td/docs/routers/access/sw_activation/SA_on_ISR.pdf
Thank you!
0 Replies 0
